It is currently Tue Oct 27, 2026 7:29 am
Post Posted: Thu Jun 10, 2010 9:45 am
I've had a few people ask me what ratios the diffs are from the Vitara that i'm wrecking. Problem is I have no idea what they are and I was hoping someone here could help me. The front diff is alloy, rear steel. Car is a 95 Vitara Estate, bog standard.
Cheers,
Jimmy
Some pics if it helps:
Post Posted: Thu Jun 10, 2010 9:47 am
Someone will probably correct me but I'm pretty sure they should be 5.12's.
The LWB From 1993. Poetry in motion :P
Post Posted: Thu Jun 10, 2010 9:51 am
count the number of teeth on the big gear, divide by the number of teeth on the small gear, instant ratios :)
Post Posted: Thu Jun 10, 2010 9:52 am
if an estate 1.6 auto OR manual its 5.1
Post Posted: Thu Jun 10, 2010 9:57 am
Onya lads, I knew I could count on you :P
Post Posted: Thu Jun 10, 2010 10:11 am
10 or 12 bolt rear crown wheel?
Post Posted: Thu Jun 10, 2010 10:13 am
What diffrance does this make????
Post Posted: Thu Jun 10, 2010 10:15 am
Ah sorry Atari, I completely forgot about your previous message :oops: I'll just go and check now.
Post Posted: Thu Jun 10, 2010 10:29 am
12 bolt.
Post Posted: Thu Jun 10, 2010 10:30 am
it depends what air locker you need to buy, early ones are 10 bolt & the later ones are 12 bolt.
Post Posted: Thu Jun 10, 2010 10:31 am
Oh ok i get lost with all this diff stuff :oops: :roll:
Post Posted: Thu Jun 10, 2010 10:42 am
Red_October wrote:
12 bolt.
cheers, now that the photos have loaded that rear diff does looks like it's got 12 bolts....
Post Posted: Thu Jun 10, 2010 11:01 am
just to clarify for those uneducated among us (me included), does 10/12 bolt mean the number of bolts holding the two pieces of the housing together? if not what does it mean?
Post Posted: Thu Jun 10, 2010 11:07 am
Im pretty sure its the amount of bolts that hold the crown wheel on
Post Posted: Thu Jun 10, 2010 11:09 am
Ah those bolts. the ones in the picture on the other side of the ring gear? That makes a whole lot more sense...
Post Posted: Thu Jun 10, 2010 11:11 am
:youdaman:
Post Posted: Thu Jun 10, 2010 11:29 am
:youdaman:
8O :P Can i have a gold star
Post Posted: Thu Jun 10, 2010 12:00 pm
8 valve engines are 10 bolt, 16 valve engines are 12 bolt.
Post Posted: Thu Jun 10, 2010 12:35 pm
sweet, i knew there was a change over just wasn't sure when.
Users browsing this forum: No registered users and 128 guests
