It is currently Mon Oct 26, 2026 2:03 pm
Post Posted: Mon Jun 14, 2010 7:06 am
G'day Guys and Gals
I have a G16A Vitara that has a few miles on it, and having a few problems. I've had the fuel solenoid removed as it wasn't idling once warm, so it idles fine now (just runs on a bit when turned off), but it's low on power, high on fuel consumption and a bit of a dog.
Just wondering if anyone knows of a carby specialist, or someone that's worked on their Zook with good results, in Newcastle.
If you could let me know who and a rough idea of price on a rebuild/tune-up, that'd be swell.
Thanks in advance.
Post Posted: Wed Jun 16, 2010 10:41 am
Bump.
Post Posted: Wed Jun 16, 2010 10:43 am
Make sure your vacuum advance is working, sound kinda like it's not..
Post Posted: Wed Jun 16, 2010 11:05 am
How do I check that?
Post Posted: Wed Jun 16, 2010 11:09 am
Not running, take the dizzy cap off, remove the vacc hose from as far from the dizzy as you can & suck on it, the button thing in the dizzy should turn a bit, not a lot but you should see it move.
If it doesn't move you either have a buggered hose or vacuum advance module..
Post Posted: Wed Jun 16, 2010 11:46 am
The timing does advance when revved. Does that prove it's working?
Post Posted: Wed Jun 16, 2010 2:53 pm
Yes
Post Posted: Wed Jun 16, 2010 11:11 pm
Jccck wrote:
Yes
No not necessarily the vacuum advance. The dizzy has both mechanical advance (rpm based) and vacuum advance (load based). Do as steak man said to see it the actuator in the dizzy is working. Then blow thru that hose connecting it to the carb, open the throttle a bit and you should be able to blow through it. Id also check if the choke flap opens up completely when warm.
Dan
Post Posted: Thu Jun 17, 2010 11:01 pm
all carbs in at newy, or there is another shop kicking around near maitland i hear about, Doctor mac woody keeps telling me about...
Post Posted: Fri Jun 18, 2010 9:06 am
Someone else recommended All Carbs to me the other day, up in Sandgate? You used them?
Users browsing this forum: Google [Bot] and 300 guests
