It is currently Sun Nov 08, 2026 7:44 pm
Post Posted: Tue Jun 15, 2010 7:48 am
is there a more weight bearing stronger suspension that will produce less sag?
Post Posted: Tue Jun 15, 2010 8:40 am
That would be the suzuki lean. Put an extra leaf in drivers side.
Member of C.O.R 4x4
Post Posted: Tue Jun 15, 2010 9:17 am
how would i do that? can i take a leaf from passengers side (weight bearing leaf) and put it on the drivers side? and do the same for the rear?
Vehicle: '94 suzuki maruti
Post Posted: Tue Jun 15, 2010 10:07 am
...am i the only one with the left sagged worse than the right?? :roll:
Post Posted: Tue Jun 15, 2010 10:19 am
its pretty rare for the left, maybe your shocks are gone? or your weight bearing leafs arent on?
Post Posted: Tue Jun 15, 2010 10:28 am
try swapping the left and right springs first... if that fails rather than adding an extra leaf and stiffening one side, look at putting a spacer under the other side to lower that side of the car in the spring pack (a cut-down leaf or 2 will do it) (assuming you're SPUA).
Post Posted: Tue Jun 15, 2010 10:50 am
thanks heaps alien! ill deffinately try swapping over the leafs, pretty sure that will work but if that doesnt i might go to heavy old man emu suspension lift and theyll fix the lean, defsf dont want to exactly fork out 1500 at the moment. really appreciated!
Post Posted: Tue Jun 15, 2010 10:57 am
you will bolt a brand new ome kit in and it will still lean within a day or two.
its part of owning a zuk i think :wink:
Post Posted: Tue Jun 15, 2010 11:01 am
i kinda guessed that, but its just so severe at the moment, anything would be good to minimalise it hoping leaf side swap will help :)
Post Posted: Wed Apr 13, 2011 5:00 am
So does that mean front and rears?
Post Posted: Wed Apr 13, 2011 12:55 pm
I always start with the rears as they are the stiffer spring and is where most of the uneven weight sits, do a measure and poss do the front aswell. Is only a temp fix though, will still lean right after time. :crazy:
Suzuki is my way of life.
Post Posted: Thu Apr 14, 2011 11:34 am
When I ordered my OME suspension set up, they asked me heaps of questions, like, my weight, what I intended it for, will there be passengers, will I be having much load in the rear etc. I have given my toy a fair thrashing, and am very pleased with the results, no sag either to the right, or either front or rear, over all, I rate OME very highly.
Post Posted: Fri Apr 15, 2011 2:32 am
Your wasting your time swapping them, give it an hour and it will be exactly the same again.
Add a spacer in like alien suggested before going out and getting new packs then.
Post Posted: Fri Apr 15, 2011 8:15 pm
Just a question,, how is it exactly do they sag, I bought a brand new set of EFS springs for mine bout 1 yr ago, my Zuke has barely left the shed ive driven it possibly 10 times , and the drivers sagged 45mm just sitting there, efs replaced them ,thank god, is there more weight on the drivers side?? Or are they really just EFS (Easilly Fuc#ed Suspension)
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Post Posted: Fri Apr 15, 2011 8:58 pm
there is more weight on the drivers side. battery, transfer, spare tyre and most of the fuel tank is on the drivers side.
Vehicle: 1992 sierra
Post Posted: Fri Apr 15, 2011 9:07 pm
As well as the driver, that seat is always occupied the other one not always.
Judging by the post your pic thread there are some cars that should be riding on the bump stops on the right hand side. :)
Post Posted: Sat Apr 16, 2011 2:12 am
Mine are OME but not sure on age, Should i get a spacer if i get new springs.
Also what is a spacer, where do you get them and can i put it in myself?
Vehicle: Daisy
Post Posted: Sat Apr 16, 2011 4:33 am
So with all this talk of suzuki lean and patching up the problems, has anyone actually tried to balance one out i.e. move the battery, shift the tank e.t.c.?
Post Posted: Sun Nov 20, 2011 4:01 am
I've just put in a brand new OME 2' lift set of springs and OME shockies and I have a 40mm drop on the right side, is that normal? Could it be something else other than the suspension, twisted chasis perhaps???? It looks ridiculous!!
The Zooks of Hazzard
Vehicle: 2018 DMAX
Post Posted: Sun Nov 20, 2011 4:03 am
Could you get a picture?.. AFAIK with the OME stuff there is a drivers side pack and passenger side pack.. Could be in the wrong way..
Post Posted: Sun Nov 20, 2011 4:08 am
Yes. Putting the battery under the passenger's seat, centring the fuel tank, and not running a spare all help. Even with all that done though, it's still normal to need an extra leaf on the driver's side.
We corner weighted a bunch of cars at a tech night earlier in the year and they were around 50Kg heavier on the RHF.
Post Posted: Sun Nov 20, 2011 4:11 am
Wow I never knew this?? :? :oops:
Vehicle: 2018 DMAX
Post Posted: Sun Nov 20, 2011 4:15 am
I may be wrong but I thought that's what was said on here :?
Post Posted: Sun Nov 20, 2011 4:33 am
Says the fat bastard :thefinger:
Post Posted: Sun Nov 20, 2011 6:02 am
They never said anything about this though?!?!
Post Posted: Sun Nov 20, 2011 6:15 am
Are you serious, are some of you guys running uneven amount of leaves one side to the other.
I wouldn't consider running more leaves one side than the other, I cannot see that as being a sound practice, I am sure that it is frowned upon and that if you are in an accident and had your car inspected it would be declared defected and unsafe, you would be hung out to dry by insurance. Please just go buy some springs or change them side to side.
Steve who did the tech night, what scales did they use and was that 50KG heavier RHF with a driver in the car?
Post Posted: Sun Nov 20, 2011 6:40 am
My preference is to put more arch (preload) on the drivers side spring.
Post Posted: Sun Nov 20, 2011 6:52 am
X 11ty billion.
My LJ actually leans 2.5cm to the passengers side. :lol:
Post Posted: Sun Nov 20, 2011 7:00 am
From memory the 50Kg was with driver.
I ran the tech night with SierraJim at his workshop. He has calibrated scales.
Yes, I am totally serious about running more rate on the heavy side. Increasing camber on the RHS eventually leads to sag returning and the process of swapping left to right continues.
More weight=more rate in my book.
PS - From memory, factory 60 series ran different packs left to right in the front.
Vehicle: On the lookout
Post Posted: Sun Nov 20, 2011 8:20 pm
My drivers side sags as per many suzukis. I put 10mm spacers into the drivers side and it still sagged. My conclusion is something is 'pulling' the suspension into that shape. I think it's the panhards because they go from uper drivers side to lower passenger side. If it was the other way around probably the passenger side would sag a little. Thats my theory. especially when you use stock panhards on a raised vehicle like I am running.
Users browsing this forum: No registered users and 99 guests
