It is currently Fri Oct 30, 2026 4:59 am
Post Posted: Wed Jun 30, 2010 10:58 am
which 02 sensor for my g16b, dissy model?? [93 vitara doner]. my wiring diagram clearly shows 4 wires, and the wiring loom also has 4. The problem is all the sellers are telling me its a 3wire sensor for a vitara. Can anyone shed some light on this for me please?
Post Posted: Wed Jun 30, 2010 11:02 am
4th wire may not be used, I don't think thay run a heated O2 in the vit's..
Vehicle: 2004 SQ625 GV
Post Posted: Wed Jun 30, 2010 11:57 am
The sellers are difficult to deal with if it is not on their wholesalers parts list it doesn't exist to them. I went to multiple car parts shops with an exact part number of my o2 sensor and they said it was the wrong part. After some hunting I found the exact part.
If there is a fourth wire it would be used. I doubt suzuki would waste money on extra wire if it is not used.
Post Posted: Wed Jun 30, 2010 1:06 pm
Wire costs 2cents not $200....
Have you seen how many spare plugs there is in a loom?
Post Posted: Wed Jun 30, 2010 8:52 pm
8O Yassss.. 8O
http://www.suzistore.com.au/shopexd.asp?id=1667
There is also single wire, & I have seen them go into a 4 pin connector....
Post Posted: Thu Jul 01, 2010 1:29 am
I has a single wire for my Baleno coilpack motor. Goes into a 4 pin plug!
Post Posted: Fri Jul 02, 2010 1:40 pm
Thats all well and good , but i still dont know which 1 for my g16b dissy
Post Posted: Fri Jul 02, 2010 2:05 pm
suzistore only list a single wire sensor for a 1.6
Post Posted: Fri Jul 02, 2010 9:57 pm
How many wire's come out of the sensor, don't worry about the plug cause you could run it through a trailer plug as long as it had a good connection..
The sensor, how many wire's come out of it??
Post Posted: Fri Jul 02, 2010 10:13 pm
the vit motor i bought did'nt come with a sensor, so i'm triing to determine what to purchase, ie, 1 wire ,2 wire ,3 wire or a 4 wire, sensor. some how the trailer plug bit went through to the boundry.
Post Posted: Fri Jul 02, 2010 10:22 pm
have a look at the sensor's, can you tell us the name of the manufacturer??
Mitsubishi, Denso?
As far as I know all the vit's are single wire, could be wrong tho, has happened before..
As for the trailer plug, the number of terminal's on a plug can have no relevance to the amount of wire's used on the sensor, even Ecu's have spare pin's out's...Hence the trailer plug.. :roll:
Post Posted: Sat Jul 03, 2010 2:21 am
my vit is a 4 wire stekko?
Post Posted: Sat Jul 03, 2010 4:31 am
If it is it's heated, so on start up it still work's efficiently..
Users browsing this forum: Google [Bot] and 921 guests
