It is currently Tue Oct 27, 2026 6:42 pm
Post Posted: Fri Jul 09, 2010 11:17 am
As the title suggests I recently snapped my sky manufactoring anti wrap bar in half. It snapped the outer tube of the twist and slid. Just wondering if anyones had similar issues or has suggestion how to make it stronger or improve the design??
Thanks
Post Posted: Fri Jul 09, 2010 12:18 pm
If you were close, i would of made u a new one..
Make a new one so it doesnt twist that last 100mm, then brace the whole lot.
Post Posted: Sat Jul 10, 2010 12:20 am
So have the internal tube go further in?
Post Posted: Sat Jul 10, 2010 2:41 am
NoOb CaD!
I think what happened: The solid bar was turning left and right, as well as up and down when extended, bending the tube at the weak point.
I would fix it this way, Original solid crossmember end, New bottom end.
So no matter where it is in the tube, the tube will not bend.
Then wait for the next breakage..
Post Posted: Sat Jul 10, 2010 4:52 am
do that and make the slip bit as long as possible so its contacting more of the inner tube...
it was leverage that broke it.
Users browsing this forum: Google [Bot] and 328 guests
