It is currently Wed Jul 29, 2026 5:21 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
Post Posted: Tue Aug 24, 2010 11:07 am
What are peoples opinions on the rocky road coil kits for the Sierra? Anyone used these?
Post Posted: Tue Aug 24, 2010 11:39 am
doesnt your truck work well enough allready?it looks like a good truck.But NO i have no advice on the kit :lol: :lol:
Post Posted: Tue Aug 24, 2010 11:57 am
I doubt there would be many of these in Australia.
And $1300 USD plus shipping would probably end up costing you $2K. :?
Post Posted: Tue Aug 24, 2010 12:15 pm
Works good but coils are the next step and more comfort
Post Posted: Tue Aug 24, 2010 1:15 pm
converting from leaf to coil isnt going to mean more comfort unless you're scarificing handling and roll stiffness for it... theres plently of softly sprung zuks out there that could not successfully reproduce a lane change test without lifting a wheel or worse, flipping over at speed... if you do convert to coils do not expect a more comfortable ride for the same performance - you might get better flex offroad but it would likely be at the cost of onroad manners (or perhaps driving the entry tracks to your favourite spot).
Post Posted: Tue Aug 24, 2010 5:43 pm
from what i'v read on the net not many people have had good experiences with that company or the quality of the kit --->
http://www.pirate4x4.com/forum/showthread.php?t=599790
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Tue Aug 24, 2010 6:50 pm
nuf said hooki.
chris weaves has that set of fandangle diffs at work ;)
also, you could prob's find a fabricator in aus that would do it for you... i know that overkill (this is 2years ago) said they would do an end for 4K... :o
anyway, let me know what you end up doing....
Post Posted: Tue Aug 24, 2010 10:44 pm
without vendor bashing, certain companies mentioned in this thread that are not rocky road offroad should not be trusted...
Post Posted: Tue Aug 24, 2010 11:44 pm
Agreed overkill have shit service
Post Posted: Tue Aug 24, 2010 11:54 pm
If your going to go coils.. are you planning rear only? or front and rear?
also i know your chasing more width etc. Why not chase some bundy diffs (the coiled ones not the middy leaf ones) and adapt all their standard bracketry to the seirra chassis? some different rate springs would see that setup work well.
Another thing i reckon would suit you would be to get a second chassis, have it linked and coiled, then swap your driveline over. If the chassis is fully linked. on wheels with diffs in, a full driveline and body swap could be done over a busy weekend, or over a couple of weekends.
weaves
Post Posted: Wed Aug 25, 2010 2:24 am
you don't have to sacrifice roll stiffness or handling for comfort when doing coils, that usualy comes from a poor ballsed up job.
Post Posted: Wed Aug 25, 2010 3:20 am
its the cars that go missing that is the drama. :wink:
Post Posted: Wed Aug 25, 2010 3:33 am
ahhh the old missing 4wd trick.... shifty 8O
Post Posted: Wed Aug 25, 2010 5:17 am
Yea width is another thing but don't want to lose clearance so would need to shave them etc. Coils would be front and rear
Post Posted: Wed Aug 25, 2010 5:18 am
Is there regs to how wide a diff u can go for street driven cars?
Post Posted: Wed Aug 25, 2010 6:16 am
ask your engineer =) lol
but really, no - so long as flares and flaps cover the rubber.
Post Posted: Wed Aug 25, 2010 6:19 am
Awesome massive diffs for me
Vehicle: LJ20 LJ50
Post Posted: Wed Aug 25, 2010 6:24 am
2500mm
Camels have nice toes
Post Posted: Wed Aug 25, 2010 6:33 am
Is that the limit? How wide are zook diffs?
Post Posted: Wed Aug 25, 2010 6:37 am
semi trailers are 2500 wide arent they.
zook diffs no where near that
Vehicle: LJ20 LJ50
Post Posted: Wed Aug 25, 2010 6:38 am
Thats the maximum width a vehicle can be without it being oversize
Now double check your state laws on Track changes.
Zook diffs range from 1000-1300mm
Post Posted: Wed Aug 25, 2010 6:51 am
Anyone have bundy diffs forsale?
Post Posted: Wed Aug 25, 2010 10:03 am
look on gumtree.com.au or start trawling toyota wreckers.
Post Posted: Wed Aug 25, 2010 10:07 am
Well thats not the case in QLD. You aren't allowed to modify the wheel track by more than 50mm or something. You can fit wider diffs, but the use of positive offset rims would be required to correct the track. :cry:
Post Posted: Wed Aug 25, 2010 11:45 am
Really that's pretty stupid. I know of zooks on Lux diffs engineered. Are bundys wider?
Post Posted: Wed Aug 25, 2010 11:46 am
Post Posted: Wed Aug 25, 2010 11:48 am
^^^^ that's QLD for you
Post Posted: Wed Aug 25, 2010 12:01 pm
Wat diffs u have weaves? They forsale or the ones ur using?
Post Posted: Wed Aug 25, 2010 12:03 pm
bundera's have the same width as hilux, the has an offset centre unlike the hilux and they have different gears. other than that they are essentially the same besides the coil/leaf mounts
Post Posted: Wed Aug 25, 2010 12:04 pm
So. :roll: Plenty of shit gets engineered, but that doesn't make it legal. DOT have full authority to overturn ANY engineering papers on the spot. And there aint a thing you can do about it.
And I believe bundy diffs are the same width as non-IFS diffs. They just have an offset rear drive.
Users browsing this forum: Google [Bot] and 563 guests
