It is currently Fri Oct 30, 2026 11:28 am
Post Posted: Mon Sep 20, 2010 10:29 pm
Just a qucik one.
Transplanting the Vit gears i have into sierra steel housings. Is it only the rear that needs the retaining can or both?
Cheers.
Post Posted: Mon Sep 20, 2010 10:36 pm
joeblow wrote:
want33s wrote:
alex wrote:
:oops: diff gears, or is that later down the track?
Steady on mate I'm not that rich 8O
I have a front Vit alloy diff with a 5.12 gearset just need another one and then buy a pair of retaining cans and I'm set.
why?....you don't need retaining cans.
I've read that some other place..
http://auszookers.com/index.php?name=Fo ... pic&t=5582
Last page..
Post Posted: Mon Sep 20, 2010 10:51 pm
That was the thread that raised the question for me. Because i was speaking with someone about it already and from what i gather only the rear required it because it was a different pin set up or soemthign like that??? (I have no real idea whats going on here 8O )
Post Posted: Mon Sep 20, 2010 11:01 pm
Is that the reason for the can's?? to hold the pin's in?? :?
Don't you have a Mig?? :lol:
What hold's em in now?? i cant see the crown wheel moving that much (that's what hold em in) going into a sierra housing that thay need can's..
Post Posted: Mon Sep 20, 2010 11:09 pm
My understanding is that, because the crowns are different sizes, when they are put into the sierra housings, the pins simply fall out. haha. So the cans keep them in place.
Also, mig... what is this mig you speak of? Do you mean meg? No body like meg. SHUT UP MEG! Nyaghhhhhhhh! (if you dont watch family guy dont bother trying to understand that)
An no, i dont have a welder.
Post Posted: Mon Sep 20, 2010 11:11 pm
I've used vit center's in sierra's before (front) & thay look the same to me..
Post Posted: Mon Sep 20, 2010 11:14 pm
front is the one i didnt think you needed a can for :S
Hahaha, hopefully someone will chime in soon and clear this up for us :)
Post Posted: Mon Sep 20, 2010 11:15 pm
:roll: I'll shut up then!!! :roll:
Post Posted: Mon Sep 20, 2010 11:19 pm
pretty sure its the fronts that need the reatiners. and the rear vitara centre gears are to big and wont fit
http://www.lowrangeoffroad.com/index.ph ... -cans.html
Post Posted: Mon Sep 20, 2010 11:27 pm
Confusion is awesome
I believe using 5.12 gears on a WT rear or NT 1.3 front or rear a can is needed
WT front never thought about but it might not but I doubt it
not needed with air lockers cause they are clerver and a little bigger
I didnt mean it like that mate.
Cheers finlay, that might just be the case.
Post Posted: Mon Sep 20, 2010 11:28 pm
4.8's would be the same deal right royce?
Post Posted: Mon Sep 20, 2010 11:49 pm
dunno, in theory the crownwheel would be smaller so it might hold it in
Post Posted: Mon Sep 20, 2010 11:53 pm
urgh, i'm opening another can of worms now :P anyone on here with 4.8's experience? lol.
Post Posted: Tue Sep 21, 2010 12:09 am
The can is required for the rear only.
I have 4.6 R&P's in WT diffs. The rear has a can, but the front does not.
Post Posted: Tue Sep 21, 2010 12:10 am
i have a 4.8 crown wheel i can maybe measure tonight.
i thought you had 5.1s?
Post Posted: Tue Sep 21, 2010 12:20 am
Nope, 4.6's. And the ID of the crown wheel is the same as 5.12's meaning the can is needed on the rear to stop the pins from falling out.
The vit crown wheels are thinner than sierra which allows the cross pins to potentially fall out. The can is fitted to stop this from happening.
Post Posted: Tue Sep 21, 2010 12:25 am
There is still much debate :( NinjaDaniel says 4.8's others opinions say 5.1's.
I wont have an idea until i pull the diff out and count the teeth i guess. haha
Cheers for that fatty, only need the one can then :D
Post Posted: Tue Sep 21, 2010 12:29 am
dont suppose you wanna sell them if they are 4.8s :)
Post Posted: Tue Sep 21, 2010 12:37 am
I could be pursueded. I'm at a cross road atm. I want 5.14:1 or 6.5:1's atm. If i do it though then i have to go to 3.9's and also make/buy a cradle... lol.
Will let you know what happens ;) got other things that are more pressing then that atm. :P
Post Posted: Tue Sep 21, 2010 12:39 am
you should only need 3.7s if you go to 6.5s and we have heaps of those. dad is just about to swap his 3.7s out for 4.6s so i could swap you those included. no great rush, they will only be for the ute when i do it.
Post Posted: Tue Sep 21, 2010 12:43 am
yeh na thats cool man, tcase gears wont be for a while anyways. have to convince myself i really need them first :P
Cheers for your help with the cans everyone!! :D
Post Posted: Tue Sep 21, 2010 4:48 am
I have a spare Can here if you need one....
Users browsing this forum: Google [Bot] and 321 guests
