| Author |
Message |
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Fri Sep 24, 2010 2:31 am |
 flame away children.....
Just a quick question, what crank pully does every one use when putting jimny pump onto a G13A?
cheers
BlueSuzy
 Posted: Fri Sep 24, 2010 2:39 am |
With the vit ps, i just used the vit pulley..
Do you have a pulley?
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Fri Sep 24, 2010 5:19 am |
I'm using the one on the eng...
_________________ I used to be indecisive,
31zook
 Posted: Fri Sep 24, 2010 6:14 am |
i thought about getting the jimny pump pully lathed down into single 'V' currently it's a multi 'V' pully....
tim, it the vit a single-milti v pully set up?
steak_knife
 Posted: Fri Sep 24, 2010 7:24 am |
Efi vit's twin multi, you will need to re-dill the mounting hole's to fit to a 1.3 tho..
oozuk
Joined: Sun Aug 16, 2009 11:30 pm Posts: 1452 Location: bethania QLD
 Posted: Fri Sep 24, 2010 9:23 am |
You can buy a pulliey from lowrange that runs the v-belt for the fan and alt and then runs a flat belt for the p\s pump 16ZUK has one on his and it works well
_________________ building a bling zook .......will it ever be finis
steak_knife
 Posted: Fri Sep 24, 2010 9:58 am |
oozuk wrote: You can buy a pulliey from lowrange that runs the v-belt for the fan and alt and then runs a flat belt for the p\s pump 16ZUK has one on his and it works well
http://www.lowrangeoffroad.com/suzuki/s ... lleys.html
MMMmmmmm, blingy..
31zook
 Posted: Fri Sep 24, 2010 12:31 pm |
cheers guy's it looks like ill just have to come up with something... lowrange order will be good, but it get expensive fast....
BlueSuzy
 Posted: Fri Sep 24, 2010 10:19 pm |
I have multi-v as of Baleno engine.
Can you get a full swap of the pulleys off a swift g13b? They are multi-v from what i have heard. Shouldnt cost much either. But a pita..
Otherwise, how big in diameter is the jimny pulley? Do some vits come out single v?
oozuk
 Posted: Fri Sep 24, 2010 11:07 pm |
Problem is that most Suzuki multi rib pullies bolt on to the crank pulley with 5 bolts unlike the Sierra that bolts on with 4 bolts. So to change over to a swift pulley you will have to change the timing gear setup to swift.
So in relaty the lowrange pulley is a cheaper and simpler option
31zook
 Posted: Tue Sep 28, 2010 9:38 am |
Hmm, i think ill buy a baleno and redrill it
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Tue Sep 28, 2010 9:46 am |
oozuk wrote: Problem is that most Suzuki multi rib pullies bolt on to the crank pulley with 5 bolts unlike the Sierra that bolts on with 4 bolts. So to change over to a swift pulley you will have to change the timing gear setup to swift.
but then u get a harmonic balancer 2. not sure if thats a big thing, i just got one because i said i needed it!
_________________ Do cool stuff, Put it on the internet Sierra build, Jimny build https://www.youtube.com/user/redzook1
