It is currently Fri Oct 30, 2026 8:14 am
Post Posted: Mon Sep 27, 2010 3:35 am
hey guys im out harvey way and my transfer case is stuck in nutrel it wont budge
i need to get home today any ideas?
thanks
89 sierra wt
Post Posted: Mon Sep 27, 2010 3:44 am
Pull the stick out and make sure the shift rods are aligned.
The right rail should be back and the left rail forward.
Your shifter sheet(bush) has most likely disintegrated otherwise you have major transfer dramas.
Post Posted: Mon Sep 27, 2010 3:48 am
if i pull the gear stick out can i move these rods manualyy with pliers or something?
Post Posted: Mon Sep 27, 2010 4:07 am
yep you will be able to use a long screw driver or pliers to move them into place the bush in the transfer will be rooted and need a new one
Post Posted: Mon Sep 27, 2010 4:09 am
ok thanks hopefully it wont take long
cheers guys
Post Posted: Mon Sep 27, 2010 4:18 am
its easy take the boot off and use like 2 screw drivers and push down and twist the cap and then the gear stick will pop out and then useing the screw driver their will be 2 rods and make sure they make a square in the middle and you should be right to go or try put the stick back in and select your gear then
Post Posted: Mon Sep 27, 2010 4:19 am
another questoin do i have to drop the transfer or can i go through the top
also dose the stick twist out or is there something holding it on
Post Posted: Mon Sep 27, 2010 4:31 am
through the top.
when you get the boot off there is a cap
just turn that anti clockwise whilst pushing down
should come out and then you can pull gear stick out
93 sierra 2"spring2"body 31,s & 4.9s
Post Posted: Mon Sep 27, 2010 4:51 am
sorry didn see the post
ok i think i got it jus need a screw driver now
Post Posted: Mon Sep 27, 2010 5:06 am
i cant seem to move the rods any suggestions
Post Posted: Mon Sep 27, 2010 5:11 am
wooooohooooooooooooo
you guys are legends i managed to use the gear stick with every thing else off
thanks a load guys i can now get home
ill replace the missing bush then
Post Posted: Mon Sep 27, 2010 5:22 am
is this a common thing for sierras as i have done it bout 3 times now its prity anoying
Post Posted: Mon Sep 27, 2010 5:28 am
it is when they have never been done before after that they should last a while are you getting them off bruce?? i got mine from him no problems at all
Post Posted: Mon Sep 27, 2010 5:31 am
good to see you got going glad to help :) now get hold of bruce on here and get a new bush for it and while your at it get the gear box bush to nd do them both at the same time
Post Posted: Mon Sep 27, 2010 6:08 am
i havent replaced any bushes or anything but i shall do that now
Post Posted: Mon Sep 27, 2010 2:53 pm
replace both bushes champ bruce sells em and you will never have another issue for a long time mine was disintegrated when i took my stick out now its nice and tight and shifts good id recommend doing both bushes gear box and transfer as they are a cheap part
Users browsing this forum: No registered users and 311 guests
