| Author |
Message |
bede
Joined: Fri Jan 08, 2010 10:30 pm Posts: 78 Location: roadvale, Qld
 Posted: Tue Nov 23, 2010 8:38 am |
hi all have a gearing question i have 4.16.1 transfer gears and 4.8 diffs 4 speed gbox what size tyres can i run for good crawl speed, it also a 1lt
royce
 Posted: Tue Nov 23, 2010 8:42 am |
probably dont wanna run any bigger than 31's or youll start to have a lot of trouble in rocks and stuff
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13015 Location: Melbourne
 Posted: Tue Nov 23, 2010 8:52 am |
I get 60:1 crawl based on your data.
What's a good crawl speed? What's a good tyre size for 60:1? It all depends on what you want to drive.
For us, 60:1 is pretty sweet with maybe a 31-33" tyre.
For the record, I like to compare crawl speed at peak torque.
A stock 1.3 sierra runs 14.6km/h @ peak torque in 1st low.
A stock 1.0 sierra runs 14km/h @ peak torque in 1st low
Your car on 31's will run 8.66km/h
on 33's 9.21km/h
on 34's 9.49
It should feel pretty good with any of those tyres, but it's very dependent on the driving you do. If you run very steep terrain, 60:1, 33's (for instance) and the tall 1st gear and tiny 1.0litre clutch might be hurting a bit, and you might prefer the 95:1 crawl ratio that 6.5 gears offer.
PS you are aware that even with 33" tyres you will be spinning at 4800rpm @ 100km/h?
Just some thoughts.
bede
ok thanks might need 6.5 reduction gears than
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Tue Nov 23, 2010 8:58 am |
Gwagensteve wrote: I get 60:1 crawl based on your data.
A stock 1.3 sierra runs 14.6km/h @ peak torque in 1st low. A stock 1.0 sierra runs 14km/h @ peak torque in 1st low Your car on 31's will run 8.66km/h on 33's 9.21km/h on 34's 9.49
Just some thoughts. Steve.
Steve, you talk of "peak torque", what is this in revs.
My 1.3s seem to love around the 4k mark, my 1.6 comes in a little lower.
_________________ Bad decisions make good stories.
bede
 Posted: Tue Nov 23, 2010 9:04 am |
my zuk does not see the black top trailer queen mainly want to drive creeks rocks
Gwagensteve
 Posted: Tue Nov 23, 2010 9:10 am |
Peak torque in a 1.3 is listed as at 3475 rpm. It's a little lower for the 1.6 at 3200 rpm (I think), but as you've noticed, the "sweet spot" - where the power and torque curves intersect, is about 4000rpm for the 1.3 and a touch lower for the 1.6 because of the longer stroke limiting revs a lowering and flattening the torque curve a bit.
The flatter the torque curve, the flatter the horsepower curve and the longer the sweet spot lasts (as in over a wider range of revs) which is why a 1.6 is more forgiving about what gear its in.
I can work out speeds at any revs but peak torque is a simple comparator, and useful for comparing different engine characteristics and their effect on gearing.
SuziBlu
 Posted: Tue Nov 23, 2010 9:36 am |
Cool, thanks
whincup
Joined: Sat Apr 17, 2010 11:30 pm Posts: 1588 Location: Gracemere, QLD
Vehicle: '94 suzuki maruti
 Posted: Tue Nov 23, 2010 9:52 am |
wow, thats actually a really good way work it out... would be really good to see dyno runs of the same car on different tyres, or the same car with different transfer gears...
