It is currently Mon Nov 02, 2026 7:04 am
Post Posted: Tue Nov 23, 2010 8:38 am
hi all have a gearing question i have 4.16.1 transfer gears and 4.8 diffs 4 speed gbox what size tyres can i run for good crawl speed, it also a 1lt
Post Posted: Tue Nov 23, 2010 8:42 am
probably dont wanna run any bigger than 31's or youll start to have a lot of trouble in rocks and stuff
Post Posted: Tue Nov 23, 2010 8:52 am
I get 60:1 crawl based on your data.
What's a good crawl speed? What's a good tyre size for 60:1? It all depends on what you want to drive.
For us, 60:1 is pretty sweet with maybe a 31-33" tyre.
For the record, I like to compare crawl speed at peak torque.
A stock 1.3 sierra runs 14.6km/h @ peak torque in 1st low.
A stock 1.0 sierra runs 14km/h @ peak torque in 1st low
Your car on 31's will run 8.66km/h
on 33's 9.21km/h
on 34's 9.49
It should feel pretty good with any of those tyres, but it's very dependent on the driving you do. If you run very steep terrain, 60:1, 33's (for instance) and the tall 1st gear and tiny 1.0litre clutch might be hurting a bit, and you might prefer the 95:1 crawl ratio that 6.5 gears offer.
PS you are aware that even with 33" tyres you will be spinning at 4800rpm @ 100km/h?
Just some thoughts.
ok thanks might need 6.5 reduction gears than
Post Posted: Tue Nov 23, 2010 8:58 am
on 33's 9.21km/h
on 34's 9.49
Just some thoughts.
Steve, you talk of "peak torque", what is this in revs.
My 1.3s seem to love around the 4k mark, my 1.6 comes in a little lower.
Post Posted: Tue Nov 23, 2010 9:04 am
my zuk does not see the black top trailer queen mainly want to drive creeks rocks
Post Posted: Tue Nov 23, 2010 9:10 am
Peak torque in a 1.3 is listed as at 3475 rpm. It's a little lower for the 1.6 at 3200 rpm (I think), but as you've noticed, the "sweet spot" - where the power and torque curves intersect, is about 4000rpm for the 1.3 and a touch lower for the 1.6 because of the longer stroke limiting revs a lowering and flattening the torque curve a bit.
The flatter the torque curve, the flatter the horsepower curve and the longer the sweet spot lasts (as in over a wider range of revs) which is why a 1.6 is more forgiving about what gear its in.
I can work out speeds at any revs but peak torque is a simple comparator, and useful for comparing different engine characteristics and their effect on gearing.
Post Posted: Tue Nov 23, 2010 9:36 am
Cool, thanks
Vehicle: '94 suzuki maruti
Post Posted: Tue Nov 23, 2010 9:52 am
wow, thats actually a really good way work it out... would be really good to see dyno runs of the same car on different tyres, or the same car with different transfer gears...
Users browsing this forum: No registered users and 434 guests
