It is currently Sun Nov 01, 2026 2:40 am
Post Posted: Tue Nov 23, 2010 9:20 am
Simple question with no doubt a simple answer...I couldn't find anthing on search :(
On my Vitara SWB it doesn't look like the secondary is opening? With the engine off and stepping on the gas I get a good shot of juice from the primary, when the engine was running, I had the missus floor it breifly and I am getting no action from the secondary? (which has the larger bore diameter on the left)
Am I missing something? At what point in the rev range, throttle position or vacuum pressure should I see the secondary open?
I am sort of hoping it indeed is not opening and once I fix it I will have another 200hp available to use at my pleasure. Or ateast enough to do a little skid when out in the sticks! LMAO! :twisted:
Thanks guys,
Post Posted: Tue Nov 23, 2010 9:38 am
it opens under vacuum load, not reved in a driveway.
Post Posted: Tue Nov 23, 2010 9:46 am
Alright, is there a way to test this in a driveway?
Post Posted: Tue Nov 23, 2010 9:47 am
rip a big skid
if it didnt open while driving it would be slow as, disconnect the vacuum hose to teh diaphragm and go for a drive
Post Posted: Tue Nov 23, 2010 9:48 am
pull off the vacuum line and one way valve if equipped and hook the line up to a port on the manifold (not carby base)......run the motor and you will see if it works.
Post Posted: Tue Nov 23, 2010 10:00 am
Righto, I was checking this in the first place as my Vit struggles to get over 100km/h with the 235/75/15's on. Does this sound about right? It is real gutless on the highway...:(
I will have a fiddle.
Vehicle: Jeep
Post Posted: Tue Nov 23, 2010 5:44 pm
Hmmm, no it shouldnt be that gutless, even with 235's... i had 215x75R15's on my old 89 Carby Vit, if i planted my foot from 100kph, i could easily wind out to 140kph... sounds more like you need the carby tuned properly, or overhauled, makes a big difference, and when did you last check the timing ?
Post Posted: Tue Nov 23, 2010 6:30 pm
Shit 140! I may get 110 on the flat. I better look at timing and you probably right, it may be worth a carbie kit. Thanks!
Post Posted: Tue Nov 23, 2010 9:11 pm
buy a vacuum pump tester from supercrap and test it by connecting it to the hose and watch the secondary to see if there is a feaction.
growing old is nature, growing up is choice.
Users browsing this forum: Google [Bot] and 94 guests
