It is currently Tue Nov 03, 2026 3:48 am
Vehicle: suzuki sierra coily
Post Posted: Sat Dec 18, 2010 10:52 am
I just picked up a h25 to put into my father inlaws wide body 2L Vitara. I got a 3L v6 turbo set up off a Mazda to adapt but I think i might start from scratch.
Has anyone else done this. I will do it, but keen for pics and ideas. Mainly manifold and turbo position. I'll do a build thread once I start.
Post Posted: Sat Dec 18, 2010 10:56 am
Room is tight thanks to the strut brace. My advise would be to fit the H25 first, then see what room you have left to work with.
Post Posted: Sat Dec 18, 2010 11:05 am
H20 standard. And h25 been sat in bay for size up. I either going pasanger side low mount and remote mount oil filter, or higher passenger mount close to manifold and changing to bango fittings on power steering pump. And mount air box passanger side. And moving oxygen sensors and moving rear coolant sensor so exhaust cross over room is achievable.
But someone must have done this before!!
Post Posted: Sat Dec 18, 2010 11:07 am
All of this is irrelevant. What are you doing for an ECU?
Post Posted: Sat Dec 18, 2010 11:15 am
Standard!!!???!!
Wat ya think. Either a good piggy back or after market. It's not my car so I wont be being a tight arse. It's just IC. Either run extra injector before turbo trigged buy comp or some sought of small water to air I don't know. I'm an auto sparky with a DYNO. I not a engineer. But I sure this one will test me. At least it's manual!
Post Posted: Sat Dec 18, 2010 11:19 am
Well it all depends how long you want it to last.
My preference would be a stand alone ECU, but thats a lot of work. A well tuned fuel and timing piggyback would do the job. Just fit a large IC, run sensible boost levels, and fit some larger injectors. +1 injector is such a crude way to go about it all. and if its a water cooled turbo, then a oil cooler wouldn't hurt either.
Post Posted: Sat Dec 18, 2010 11:32 am
Aftermarket ecu is a sinch. Fitted plenty. My car was the 1st I've done for my self were money mattered. Do not worry about IC or comp.
I just hoped some one could help on exhaust manifold. I have 2 turbos to choose from. GT25 or GT28. Or the Mazda 3L original. But haven't seen yet. I was hoping the japs have done it and I can copy. Or someone has done it.
Vehicle: LJ20 LJ50
Post Posted: Sat Dec 18, 2010 4:30 pm
fit twin turbos with different spool rates and make separate manifolds. easy fixed
Camels have nice toes
Post Posted: Sat Dec 18, 2010 8:51 pm
Then you'll have different backpressure for each bank of cylinders.
Don't dick with 2 turbos, go one and make it the T28 IMO. You'll have 2.5 litres to spin it up, just try to avoid a log manifold if possible.
I'd do it same as Fatzook suggests, mount the engine and go from there. When finding a spot for the turbo keep in mind the exhaust routing. It will be a bit tight I think. But cool!
Post Posted: Sat Dec 18, 2010 8:55 pm
could you bring the pipe from one bank around the front of the engine underneath? then they can match up and you still have some room to get the exhaust out the back?
whichever way you go, get lots of pics!!!
Post Posted: Sat Dec 18, 2010 9:27 pm
super charge would be easier, like a aurion or lexus sc12
josh AKA Bazook
Post Posted: Sat Dec 18, 2010 10:00 pm
SC12 wouldn't be that much easier really, you still have to mount the thing and plumb it.
M90 eaton would fit in the V, but would need a custom inlet manifold.
Post Posted: Sat Dec 18, 2010 10:06 pm
And bonnet mods. I have an M45 here and even with the lowest possible inlet manifold it will still most likely occupy more room than whats under the bonnet ( unless a body lift is fitted maybe).
Would be cool though :lol:
Post Posted: Sat Dec 18, 2010 10:19 pm
Dezook is blowing his 2.5L. And has fitted 3 inch bodylift to fit it.
Going infront of engine is no good. Believe it or not but the Mazda cross over pipe fits neatly around back of engine above bell housing. It's just that one temp sender that I'll relocate. I think the 28 is Wat I'll go.
Does any of you guru lads do or know of a remote oil filter for the v6
Post Posted: Sun Dec 19, 2010 12:06 am
http://www.google.com.au/search?q=remot ... =firefox-a
Hundred's of em.. :P
Post Posted: Sun Dec 19, 2010 12:11 am
I remember a guy getting some bits from Just Jap for one?
Post Posted: Sun Dec 19, 2010 4:55 am
This is something I've been toying with also. Problem is that you can't run an intercooler, which is something i want considering most of my driving will be along hot beaches at highish RPM...
In terms of H25 turbos, this is the best I've found so far...
http://www.cardomain.com/ride/338504/19 ... utility-4d
Not the greatest kit nor piping layout, but is possible.
My thoughts are to do a setup not too dissimilar to the one below. I love the simplicity and neatness of the "tube" water-air intercooler. This photo is from an MX5, but the concept will work on most cars.
Post Posted: Sun Dec 19, 2010 5:22 am
Yeah it will be a tricky one but it not impossible. I'll order the flange profiles and get designing...
Vehicle: 2018 DMAX
Post Posted: Sun Dec 19, 2010 5:37 am
If space is an issue just go for a rear mount turbo.. Saves dicking about with a new manifold, and generally with the long pipe from the turbo to inlet you wont need an IC with moderate boost.. Theres alot of these setups out there that work well..
Post Posted: Sun Dec 19, 2010 8:29 am
I've seen that in america. They mount turbos just near rear if car. And use a smaller turbo then normal. But I will get it under the bonnet. Should be sweet.
Post Posted: Sun Dec 19, 2010 8:41 am
http://priuschat.com/forums/attachments ... o_02_z.jpg
Air cleaner wouldn't get dirty would it :roll:
Post Posted: Sun Dec 19, 2010 8:45 am
Can you safely run any boost on a stock ecu?
Post Posted: Sun Dec 19, 2010 8:49 am
All depends on if the ecu, injectors, and so on can cope. But 9 times out if ten no.
Post Posted: Sun Dec 19, 2010 9:16 am
coneykid wrote:
http://priuschat.com/forums/attachments/gen-ii-prius-modifications/9501d1212073362-bypass-filter-install-148_0502_turbo_02_z.jpg
That's some seriously nasty plumbing on the dump-pipe!
Post Posted: Sun Dec 19, 2010 9:25 am
Well its deserving of shitty workmanship. It is a Prius afterall. :lol:
Vehicle: 2018 DMAX
Post Posted: Sun Dec 19, 2010 10:09 am
I think it needs tobe something more like this 8O Im sure a vitara has enough room up back
Post Posted: Mon Dec 20, 2010 5:23 am
do old school and run it the turbo at the cat
josh AKA Bazook
Post Posted: Mon Dec 20, 2010 6:57 am
Yeah that's my next thought. Just were the two exhaust meet there is tones of room. Mount one there. Only prob the is a scavenge pump for oil return.
Post Posted: Mon Dec 20, 2010 7:24 am
And rapid cooling through water crosings.
High and dry is best.
Post Posted: Mon Dec 20, 2010 7:27 am
Yeah I know. That's only issue. A lot of playing around with this one.
Users browsing this forum: Google [Bot] and 477 guests
