It is currently Mon Nov 02, 2026 10:03 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
Post Posted: Sat Dec 18, 2010 11:15 am
just wondering what tyre pressure you would use in different situations
atm i have 215/75*/15 (*i think) BFG a/t
what pressure should i use for dirt roads/gravel, mud/rocks, sand
Post Posted: Sat Dec 18, 2010 11:25 am
well gravel/dirt roads i would really worry about airing down unless it got really soft ..
sand can be down to about 12 or so psi ..
and mud and rocks about 15 ta 10psi .. but alway make sure u have a way to air up from them sorta low presures as it can make for a scary drive on the black top lol
that just how i used to work with my sierra .. so may be a bit different for ur vit
-indebt 4x4 club-
nav 32s n winch cust rear
Post Posted: Sat Dec 18, 2010 11:28 am
yeah pretty much what buz said. when u do need to go down, start around the 15psi mark and if u still can get to ur location drop down to 10-12. if ur down on the beach and it gets really boggy and still cant get through with them at 10, go down to 7-8, but i wouldnt go much lower than that.
just have a play with them and see how u go.
Mitch
Post Posted: Sat Dec 18, 2010 11:41 am
ok cheers, just wondering cause i punctured a tire the other day pulling a landcruiser ute up a hill aha
my tires were at like 30psi from when i bought it 8O , so im guessing that was why.
Post Posted: Sat Dec 18, 2010 11:43 am
i use between 3 and 7 psi for dirt and 14psi for highway.
Post Posted: Sat Dec 18, 2010 11:44 am
30 psi damn .. i used to have mine at a bout 25 psi for on road use .. (but again was a sierra) if ur doing some simple offroading simple sorta rutted track bit or mud just drop to about 20 psi (stop alot of staking of ur tyres ).. and u will be laughing
-indebt 4x4 club-
Post Posted: Sat Dec 18, 2010 11:58 am
shut the fuck up if you dont know what you are talking about. :wink:
low pressures is how you prevent tyre damage in the bush.
the manufactures recommended pressure for on road in a sierra is 20 to 22psi
Post Posted: Sat Dec 18, 2010 12:10 pm
on my placard it said 28 psi was recomended so i dunno then shep .. .. but i never had aproblem running 20 psi in the bush but owell each to his own .. stil gotta be a shit oad softer then 30 psi
-indebt 4x4 club-
Vehicle: Jeep
Post Posted: Sat Dec 18, 2010 12:21 pm
30psi is too much, you must have had a bit of a hard ride at 30psi, let them down and you will notice how much more comfortable it is... there is a tyre placard, inside the drivers door, just under the door latch, i would stick to what it says for on road, and no it doesnt matter what size tyre you put on, just use the Suzuki recommended tyre pressure, on the tyre placard... from memory i think its 24psi for a Vit.....
Post Posted: Sat Dec 18, 2010 12:41 pm
after we fixed the puncture with one of those sticky rope things, i used dads pressure gauge thing to pump it to 23psi (following the manual)
driving it today i noticed it was handling like shit so went to the servo and used the digital thing.
i got a bit of a shock when the first tyre said 33psi in it :/
i havent really needed to let the pressure down so far, mostly just driving mud and big puddles, might drop em to 15psi next time and see how that goes
Post Posted: Sat Dec 18, 2010 12:48 pm
different tire size all up, but 31s on our jimny we run 25 on road, for gravel road about 16, rocks and mud around 12 and sand 7.
that works for us pretty well
dodgy brothers mechanical
Post Posted: Sat Dec 18, 2010 1:51 pm
mine on 31s:
Simex: 20 on road, 5-7 offroad (any terrain)
BFG KM2: 25 on road, 10 offroad (any terrain)
the simex are super stiff and even at 5psi i wanted to go lower to soften it up, but couldnt comfortably do it not having beadlocks. the BFG KM2 now fitted are far softer and need 25psi on the road to make a proper contact patch (20psi and the sidewalls touch the road on corners!) - 10psi worked VERY well last time i went out, they bagged out HEAPS.
dont forget that each tyre only has around 250kg on it under a sierra, obviously its more like 350kg on the front and 150 on the rear, but either way running at 30psi etc is just crazy and will be way too stiff.
this said - when i did the lane change test in my sierra my tyres were at 35psi to stiffen the sidewalls...
Post Posted: Sat Dec 18, 2010 2:18 pm
yea ive only had my vitara for less than a month and today was the first time i checked the tyre pressure, to find them at 30+psi..
and after a day of 4x4ing too haha
lane change test??
Post Posted: Sat Dec 18, 2010 9:10 pm
Picture of placecard..
will be 26 max
20 normal.
for a sierra.
i use 8psi on rocks, 12psi on sand and highway everywhere else (25psi)
Post Posted: Sat Dec 18, 2010 9:13 pm
i use 10-12. offroad
Alot of sierra drivers run lower. but im scared of popping a bead
20-26 onroad.
Post Posted: Sat Dec 18, 2010 9:29 pm
i have 5.5inch rims on 275s... it's will not come off the rim 8)
Post Posted: Sat Dec 18, 2010 9:34 pm
20-26 onroad.
i have only ever popped a bead once and that was at 3psi and towing a
trailer with my boat on it. :wink: and rock hopping through a dry creek bed.
i couldn't be stuffed driving hard/fast but.
When I got the BFG AT's 215-75's on my Jimny, the guy at the tyre place said to keep them up to about 35psi (he said they should be alot higher than the standard tyres.)
So I should let them down to about 26psi on bitumen?
And about 20psi for dirt?
 Profile YIM
Vehicle: Vitara 90'
Post Posted: Sat Dec 18, 2010 9:39 pm
Fark :!: , Don't worry about calling me names, I'm to used to sedan's etc, I've been running 35psi on road... :oops: :oops: :oops:
I think I might change that. :idea: :roll:
Post Posted: Sat Dec 18, 2010 9:42 pm
start with the recommended pressure on your placard and then half it for medium speed off road.
go lower if ya need to.
in 25 years of lots and lots of bush driving i have only had 3 tyres staked and only once have i poped a bead.
i dont drive hard and i run lowish pressures.
Post Posted: Sat Dec 18, 2010 9:48 pm
thanks mate.
Going to lower pressure now.
 Profile YIM
Post Posted: Sat Dec 18, 2010 9:58 pm
20-26 onroad.
Yeah see, i like donuts.
Post Posted: Sat Dec 18, 2010 10:01 pm
20-26 onroad.
i used to like donuts in my swb but after a big 2 wheel incident they scare me a bit now. :oops: :lol:
Post Posted: Sat Dec 18, 2010 10:06 pm
Does anybody know what PSI the original tyres on the Jimny recommended ?
It is really high on the BFG's...
 Profile YIM
Post Posted: Sat Dec 18, 2010 10:08 pm
If it's the tyre fitter telling you that it's BS, jim's like around 24 on road..doesn't matter the trye
Post Posted: Sat Dec 18, 2010 10:16 pm
another question: do people run like 0 psi with beadlocks?
Post Posted: Sat Dec 18, 2010 10:22 pm
my feeling on tyre pressures is that within reason the larger the tyre you run on a given car the lower the air pressure required unless you are increasing the load carried.
so if 28 psi is the max recommended on say a 215 75 15 then 20-22 would probably be about the max i would run in say a 31 10 15
obvoiusly ply rating an carcass type( ie radial/basis) will affect these too.
my 34 swampers handle as good at 10 psi on the road as they do at 20psi
and you could probably drive around on the black top at 7 - 10 psi and not even know they were that low, but you would be had pressed to do that on say a 235 75 15
I think a good pressure to run on say a 31 10 15 radial tyre would be
around 18-22 psi on road
and 10-15 psi for general bush work
and 10 or under for rock and mud
JMO
Post Posted: Sat Dec 18, 2010 10:28 pm
I run between 3 and 5 psi usually if I can be fucked actually putting a guage on them.
I have low pressure stauns (0 - 10 psi) that will let then down to somewhere between 2 and 6 psi (yes they are that accurate) so usually they deflate to whatever the staun stops at and I drive on it
Post Posted: Sat Dec 18, 2010 11:51 pm
larry wrote:
lane change test??
part of engineering your vehicle in WA... search youtube for sierra lane change test and you'll find my vid.
Users browsing this forum: No registered users and 85 guests
