| Author |
Message |
ellis
Joined: Wed Sep 08, 2010 8:28 am Posts: 445 Location: GYMPIE QLD
 Posted: Sun Jan 16, 2011 8:15 am |
will a jimny rear diff bolt straight in to my coily sierra
_________________ if u drive a loud toyota ute u drink rum
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Sun Jan 16, 2011 8:22 am |
Nothing fits a coily  Why bother putting in another weaker unit that has little to no aftermarket quality performance parts?? W/T diff all the way buddy  JMO though
What is your reasoning??
_________________ Shep is a closet jimny lover!!!!
ellis
 Posted: Sun Jan 16, 2011 8:29 am |
i got a auto locker in the rear atm and i want to put in a air locker there is a jimny at the wreaker so i thort i would just grab the diff from that put the air locker in that and just sell my diff with the auto locker in it and btw do the wt diffs bolt in???
Rusho
 Posted: Sun Jan 16, 2011 8:33 am |
ellis wrote: btw do the wt diffs bolt in???
Definately not...cut existing mounts off, glue on new coil/control arm mounts and have it all in the correct geometrical position.
Send Tuffsuzi a PM...pretty sure he has a jimny diff in the front of his coily
ellis
 Posted: Sun Jan 16, 2011 8:36 am |
when i mean diff i mean just the diff housing
Rhino
Joined: Tue Oct 13, 2009 10:30 pm Posts: 928 Location: Sunny Coast
Vehicle: 79 Lj80 stockman 94 swb Sierra
 Posted: Sun Jan 16, 2011 10:46 am |
ellis wrote: when i mean diff i mean just the diff housing
 You've lost me
I was going to suggest just buying a NT diff center,
but im not realy sure if thats what you were asking...........
Benz
Joined: Mon Oct 27, 2008 10:30 pm Posts: 1006 Location: Cervantes WA
 Posted: Sun Jan 16, 2011 1:17 pm |
yeah you should to be able to get another diff coily centre put the locker in that and swap them over????
then sell the other centre?
jimny centre might have different ratios?
cbzook
Joined: Sat Sep 13, 2008 11:30 pm Posts: 272 Location: Port Macquarie
Vehicle: 6.5s, gti, 31 extremes
 Posted: Sun Jan 16, 2011 9:05 pm |
They don't make lockers for front diffs in coilys because there shit house diffs
_________________ Twincam coiler, rocktoy, 6.5s, lift, 31 extremes
Benz
 Posted: Sun Jan 16, 2011 11:31 pm |
did he not say rear diff?
unless you cant get a airlocker for that?
swapping a whole diff seems like alot of work for a locker
Rusho
 Posted: Mon Jan 17, 2011 12:27 am |
Benz2369 wrote: swapping a whole diff seems like alot of work for a locker
It's the only option for us coily owners
BlueSuzy
 Posted: Mon Jan 17, 2011 12:57 am |
The coily rear diff "centre" should be the exact same as a 1.3 sierra/rear jimny centre/or front vit. Low Pinions
The fronts are HP.
The "Whole" Jimny rear diff will be wider. And i doubt the brackets/mounts will be in the same exact position. 4.09 ratio. Coilys are different ratio. 3.9?
ellis
 Posted: Tue Jan 18, 2011 12:00 pm |
ok thanks i did not think about the different ratio's
