It is currently Fri Jul 31, 2026 3:30 am
Post Posted: Sun Jan 16, 2011 8:15 am
will a jimny rear diff bolt straight in to my coily sierra
if u drive a loud toyota ute u drink rum
Post Posted: Sun Jan 16, 2011 8:22 am
Nothing fits a coily :roll: Why bother putting in another weaker unit that has little to no aftermarket quality performance parts?? W/T diff all the way buddy :wink: JMO though :roll:
What is your reasoning??
Post Posted: Sun Jan 16, 2011 8:29 am
i got a auto locker in the rear atm and i want to put in a air locker there is a jimny at the wreaker so i thort i would just grab the diff from that put the air locker in that and just sell my diff with the auto locker in it and btw do the wt diffs bolt in???
Post Posted: Sun Jan 16, 2011 8:33 am
Definately not...cut existing mounts off, glue on new coil/control arm mounts and have it all in the correct geometrical position.
Send Tuffsuzi a PM...pretty sure he has a jimny diff in the front of his coily
Post Posted: Sun Jan 16, 2011 8:36 am
when i mean diff i mean just the diff housing
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Sun Jan 16, 2011 10:46 am
:? You've lost me :?
I was going to suggest just buying a NT diff center,
but im not realy sure if thats what you were asking...........
Post Posted: Sun Jan 16, 2011 1:17 pm
yeah you should to be able to get another diff coily centre put the locker in that and swap them over????
then sell the other centre?
jimny centre might have different ratios?
Vehicle: 6.5s, gti, 31 extremes
Post Posted: Sun Jan 16, 2011 9:05 pm
They don't make lockers for front diffs in coilys because there shit house diffs
Twincam coiler, rocktoy, 6.5s, lift, 31 extremes
Post Posted: Sun Jan 16, 2011 11:31 pm
did he not say rear diff?
unless you cant get a airlocker for that?
swapping a whole diff seems like alot of work for a locker
Post Posted: Mon Jan 17, 2011 12:27 am
It's the only option for us coily owners :cry: :roll:
Post Posted: Mon Jan 17, 2011 12:57 am
The coily rear diff "centre" should be the exact same as a 1.3 sierra/rear jimny centre/or front vit. Low Pinions
The fronts are HP.
The "Whole" Jimny rear diff will be wider. And i doubt the brackets/mounts will be in the same exact position. 4.09 ratio. Coilys are different ratio. 3.9?
Post Posted: Tue Jan 18, 2011 12:00 pm
ok thanks i did not think about the different ratio's
Users browsing this forum: No registered users and 416 guests
