It is currently Mon Nov 02, 2026 8:19 pm
Vehicle: 4wd
Post Posted: Thu Jan 20, 2011 10:39 am
Just tried to start the motor.
Motor cranks strong, getting fuel (plugs wet) but no spark. :cry:
I have checked power etc and everything that needs it is getting a strong 12.4 volts.
I'm thinking crank sensor, but what do I check?
Thanks in advance.
Watch out or you'll get sued.
Post Posted: Thu Jan 20, 2011 11:04 am
Cam and crank sensor talk together. Not really sure on how to get engine codes. Never had a problem.. Some one else will pipe up
Vehicle: 4wd
Post Posted: Thu Jan 20, 2011 12:25 pm
Got it going.
When it starts up it jumps to a real high idle around 4000 rpm. Anyone know why?
Post Posted: Thu Jan 20, 2011 12:37 pm
Well its good its going..
4k! Sticky throttle? Sicky throttle position sensor on side? quirky sensor. Ive had one rev higher than normal, but not 4k.
Vehicle: 4wd
Post Posted: Thu Jan 20, 2011 12:39 pm
I disconnected the throttle cable and still the same. The butterfly is closed but still screams.
Vehicle: 4wd
Post Posted: Thu Jan 20, 2011 8:06 pm
Let it run for a couple of minutes and the idle drops a little but still runs high.
Now it runs high then drops off, then high and off and keeps repeating.
Video on the way
Vehicle: 4wd
Post Posted: Thu Jan 20, 2011 8:13 pm
http://s93.photobucket.com/albums/l44/Y ... I_1513.mp4
Post Posted: Thu Jan 20, 2011 8:55 pm
Do you have an air temp sensor? I had one, but disconnected it because it would idle up and down, moody though. 3days out of 7. It also held a high idle at times..
Fuel economy was no different.(rich)
Vehicle: 4wd
Post Posted: Fri Jan 21, 2011 7:07 am
Yeah got the air temp sensor plugged in. Knowing that the motor ran well before I took it out of the baleno I want to keep all the sensors etc connected.
Anyway all fixed. Purrs like a kitten.
Post Posted: Fri Jan 21, 2011 8:00 am
what was it?
Post Posted: Fri Jan 21, 2011 8:05 am
what was it?
Ditto....
Users browsing this forum: Google [Bot] and 105 guests
