It is currently Tue Nov 03, 2026 12:22 pm
Post Posted: Thu Jan 20, 2011 10:36 am
Hey guys,
Looking at getting some rims off low range but I'm after a decent offset and they have "backspace". Does anyone know what "backspace" is? I've never heard of it before.
Suncoast Exhaust & Mechanical,Noosa,QLD. All Mecha
Post Posted: Thu Jan 20, 2011 10:40 am
http://www.auszookers.com/index.php?nam ... =backspace
Brendan got his 16's from lowrange, but for his Navara.
Post Posted: Thu Jan 20, 2011 10:41 am
its the measurement from the mounting surface to the inside egde of the wheel. kinda like rim offset but different
Post Posted: Thu Jan 20, 2011 10:49 am
So the bigger the backspace the littler the offset?
Post Posted: Thu Jan 20, 2011 10:50 am
DID YOU READ THE THREAD?
Post Posted: Thu Jan 20, 2011 10:53 am
The more backspace a rim has, the greater its positive offset. ( or lesser negative offset :? )
Post Posted: Thu Jan 20, 2011 10:59 am
Fatzook has understood what I've said. So if the rim is an 8" wide rim with a backspace of 4" that theoretically means there is 100mm of negative offset? just trying to work the maths.
Post Posted: Thu Jan 20, 2011 11:07 am
No. Offset is measured from the centre of the rim.
So a 8" rim with 4" backspace has a 0 offset :wink:
Post Posted: Thu Jan 20, 2011 11:08 am
DID YOU READ THE THREAD THAT I POSTED??
8"rim-4"backspace=1/2 a rim. Which is the centreline=0mm offset
Post Posted: Thu Jan 20, 2011 11:21 am
Sorry bluesuzy didnt quiet understand the full way it worked. I'll do some working out to see exactly what backspace I need to get
Post Posted: Thu Jan 20, 2011 11:46 am
So you understand that Offset is measured from the centre of the rim? So positive offset will move the wheel centre out, which inturn locates the wheel further under the car. Negative is ofcoarse the opposite, making the wheel stick out from the wheel arch.
Backspace is just another way of measuring offset.
Post Posted: Fri Jan 21, 2011 8:12 am
:P Are you angry??? :P
Post Posted: Fri Jan 21, 2011 9:28 am
was
Post Posted: Fri Jan 21, 2011 9:30 am
i think he's suffering from post natal suzuki syndrome?
Post Posted: Fri Jan 21, 2011 9:55 am
yet to re-birth. :lol: legit though.
Post Posted: Fri Jan 21, 2011 10:05 am
is that rebirth or afterbirth?
Post Posted: Fri Jan 21, 2011 10:08 am
re-inCARnate
Post Posted: Fri Jan 21, 2011 11:16 pm
Backspace is also a "simple" way (aka Dumb) to know what rims will not foul on chassis components for a particular vehicle. eg if your stock rims have 3 1/2 inches of backspace and do not hit the chassis, springs or steering components, then an 8" rim with 3 1/2" of backspace will also clear, or a 10" rim, etc.
It is a dumb way because it does not take into account fouling bodywork or bumpers, or the clearance issues of taller or wider tyres, or the effect of offset on camber and caster.
Users browsing this forum: Google [Bot] and 94 guests
