Joined: Wed Jan 05, 2011 7:31 am Posts: 114 Location: oz
Posted: Sat Jan 22, 2011 3:12 am
Does anyone know if there is any difference between the following SJ80 coily shocks? The all look the same if you disregarding the springs. The SuziStore shocks are unnamed but look like Ultima shocks and BluePac make a range of shocks including the Ultima brand.
Joined: Mon Nov 15, 2010 9:49 am Posts: 15 Location: Central Qld
Posted: Sat Jan 22, 2011 8:45 am
i think (I maybe be wrong) ultima do a s/s shock which is stock standard part number 36S606A and a raised spring shock 36S607A for the front. not to sure if the back is raised or standard but the part number is 360603
I got the ultima/king spring raised kit off ebay and im sure its the same as the suzisport one and a bit cheaper. it has good lift and good ride.
hope this helps
Users browsing this forum: Google [Bot] and 394 guests
