It is currently Tue Nov 03, 2026 2:14 pm
Post Posted: Sat Jan 22, 2011 3:12 am
Does anyone know if there is any difference between the following SJ80 coily shocks? The all look the same if you disregarding the springs. The SuziStore shocks are unnamed but look like Ultima shocks and BluePac make a range of shocks including the Ultima brand.
SuziStore - 35mm Suspension lift kit to suit coil sprung Sierra - http://www.suzistore.com.au/shopexd.asp?id=1709
Ultima - 30mm Bore GT Gas Ultima Shock Absorbers with Multi Disc Valving - http://cgi.ebay.com.au/Suzuki-Sierra-SJ ... 1e61006124
Blue Pac - Suzuki SJ80 Coil Model 40mm Lift Suspension Kit 1996-98 - http://cgi.ebay.com.au/Suzuki-SJ80-Coil ... 3cb3b364fc
Post Posted: Sat Jan 22, 2011 3:15 am
Pretty sure the Ultima and Blue Pac are either the same company or one is part of the other company.
As for the suzistore ones, who cares its $895 :P
I ran the Blu Pac ebay job in mine, was great for the money
Post Posted: Sat Jan 22, 2011 3:31 am
Post Posted: Sat Jan 22, 2011 8:45 am
i think (I maybe be wrong) ultima do a s/s shock which is stock standard part number 36S606A and a raised spring shock 36S607A for the front. not to sure if the back is raised or standard but the part number is 360603
http://www.australianautomotiveparts.co ... hocks1.pdf
page 24.
I got the ultima/king spring raised kit off ebay and im sure its the same as the suzisport one and a bit cheaper. it has good lift and good ride.
hope this helps
Post Posted: Sun Jan 23, 2011 11:27 am
I heard back from SuziStore their SuziSore shocks are re-labeled Ultima shocks.
Users browsing this forum: No registered users and 514 guests
