It is currently Tue Nov 03, 2026 3:12 pm
Post Posted: Wed Jan 26, 2011 9:30 pm
Anyone got a link for manufacture/purchase of Vitara twin transfers or just the adaptor?
Post Posted: Wed Jan 26, 2011 9:46 pm
OTT Kicker 3 doubler
Use your sierra case....
OTT
Post Posted: Wed Jan 26, 2011 9:51 pm
OTT
Want to use TWO Vit transfers...... Need central rear output.
Post Posted: Wed Jan 26, 2011 10:00 pm
Im not aware of any that use 2 vit cases. There are a few that use a vita and a toy case, so you still get the centre output.
Also others that convert to W56 or similar with marllin twin toy cases, but I've not seen a twin vit case kit thats off the shelf.
The OTT kicker 2 uses a modded vit case with an adaptor to toy transfer. Probably the closest you will get without custom making it. :?
Post Posted: Thu Jan 27, 2011 12:20 am
I have seen a few but cant remember where
U have to cut the front output shaft off the old case and have a plate tiged over the hole then I think they bolt together with just a splined coupler between them
Have a look on zukiworld there are a few people on there with them
Wat r u going to do about high range
Post Posted: Thu Jan 27, 2011 3:03 am
5.12 diffs will help.
I'll be running 35" tyres so can always put one case in low if needed... I don't drive on the road and max speed in the bush is 70 km/h or so.
Post Posted: Thu Jan 27, 2011 6:41 am
Do u mean vit then the serria box
Post Posted: Thu Jan 27, 2011 6:44 am
OTT
I want my old sig back :(
Post Posted: Thu Jan 27, 2011 6:50 am
if you make it work want 33's take pictures and tell me how may be handy when i go bigger tyres
Vehicle: Daisy
Post Posted: Thu Jan 27, 2011 6:53 am
How good it would be to have a second high/low lever!
Pity they are so expensive!
One would still have to stop to change one of these between ranges yes?
Post Posted: Thu Jan 27, 2011 6:56 am
Yes, no synchros in a transfer means a stop is necessary to shift between ranges.
Post Posted: Thu Jan 27, 2011 7:46 am
http://www.pirate4x4.com/forum/showthre ... ker+to+toy
kicker 2 goes modded vitara to toyota
joeblow might like to add something on the possibility of dual vit cases, the removal of the front output is well known now so another transfer on the back might be possible
Post Posted: Thu Jan 27, 2011 7:47 am
what about the guy on here putting the v6 in a sierra and he has used a lux transfer case on a vitara box because its a bolt up. you could just use a twin kit for a lux then.
don't know if its the same box between the 1.6 and 2.5
only other way i can think of is how joe cuts them for twins in a sierra but you make it so a stock tcase bolts up to the cut tcase
Vehicle: Daisy
Post Posted: Thu Jan 27, 2011 8:17 am
Yeh I realised that, just wasn't sure if it was some form of gearbox addition then I realised it's just a second transfer case that goes between the gearbox and the original transfer case.
Still, provided you had 1:1 for high range (unless you wanted permanent reduction) then you would only be gaining extra range!
Post Posted: Thu Jan 27, 2011 11:07 pm
Got a link to that thread Brett? That might be the way to go. Would also save the drama of the Vit front output being the slip joint.
I just rang OTT in Canada and they aren't making any Kicker setups for 2-3 months as they are downsizing factories and have been hit hard by the "GFC" :roll:
Post Posted: Thu Jan 27, 2011 11:12 pm
http://www.auszookers.com/index.php?nam ... pic&t=9848
V6 box differs to teh 1.6 box though, guess youll have to fit a 2.5 now :)
Post Posted: Fri Jan 28, 2011 12:46 am
You could also look at the Trail Tough "Undertaker" as a good bolt in solution
Undertaker
Post Posted: Fri Jan 28, 2011 5:50 am
Undertaker
$1295 8O 8O
Looks like a possible solution...
The other problem I have is eliminating the slip joint from the front output.
In the picture below from the undertaker link is a bolt on flange but Trail Tough don't list it.... Any ideas???
I have a mate that runs a CNC lathe and mill for a living, might talk to him about mating hilux (ewww wash my mouth out) transfer to Vitara box which gives me more gearing or twin transfer options down the track.
Post Posted: Fri Jan 28, 2011 6:13 am
want33s wrote:
In the picture below from the undertaker link is a bolt on flange but Trail Tough don't list it.... Any ideas???.
Slip yolk eliminator
Post Posted: Fri Jan 28, 2011 6:30 am
"Works on 91+ models"
:roll: That'd be right I have an 89 transfer.... Pete you still got the transfer I gave you with the gearbox?
Post Posted: Fri Jan 28, 2011 6:32 am
yep. Come get it :lol: I tripped over it last night, soyou had better be quick or it will be landfill :x
Post Posted: Fri Jan 28, 2011 6:35 am
Awesome. :D .. Will try to get down there by mid next week.. Will call to arrange a time.
Post Posted: Fri Jan 28, 2011 6:39 am
mate you can take your time last time he said he needed to go to the dump it took him almost a month to actually go plus he doesnt have the ute or a tow ball on the vit
cool. I'll empty the water out of it. :lol: JK
Post Posted: Fri Jan 28, 2011 6:45 am
If your going to make the trip we should all go wheeling :D
Post Posted: Sat Jan 29, 2011 1:07 am
We made our own slipyoke eliminator,
use a flange from a diff, you will find it has the same splines, you will need to weld in a nut or something like that to the flange and get the output shaft tapped and bolt put in but it works great.
Users browsing this forum: Google Adsense [Bot] and 85 guests
