Joined: Mon Oct 11, 2010 5:14 am Posts: 542 Location: Newcastle
Vehicle: Work van
Posted: Thu Jan 27, 2011 4:44 am
I searched but didn't find anything, the transfer arms I got from a wrecker for my rockring, the log arm has big holes where the rubber mounts bolt up to instead of the 3/8? Hole and smaller locating hole, would it be safe to weld a plate in and drill the holes that I need?
_________________ Swb softie spoa cromo front -50 beadlocks 6.5s
Vehicle: Work van
Posted: Thu Jan 27, 2011 8:57 am
Yea dies to make the sheet stronger, using them because they are super cool and so I can brace my ring to the arms with 3mm plate and still keep it strong, the bigger holes will just be plated glued then re drilled with the right holes
Users browsing this forum: Google [Bot] and 100 guests
