It is currently Fri Oct 09, 2026 9:07 am
Post Posted: Mon Feb 07, 2011 11:01 pm
Possibly dumb question but does coily seats fit into a leaf sierra?
like does all the brackets and everything line up or would you need to mod it abit.
Yeah Cheers Kent~!
Post Posted: Tue Feb 08, 2011 1:01 am
Completely different brackets mate. It would be far easier to put aftermarket seats in a leafy then coily ones
Vehicle: SJ80, SE416
Post Posted: Tue Feb 08, 2011 1:02 am
Rails are completely different. Coily seats have side mount rails - leafy seats are top mount.
Post Posted: Tue Feb 08, 2011 1:28 am
true righto thanks heaps guys
Yeah Cheers Kent~!
Post Posted: Tue Feb 08, 2011 3:20 am
Bugger have a set of these in the shed...
Post Posted: Tue Feb 08, 2011 7:06 am
The bin is a better place for them :wink:
Vehicle: 96 suzuki sierra
Post Posted: Thu Aug 10, 2017 8:56 pm
Are the bottom mounts, that go into the floor the same though?
Post Posted: Fri Aug 18, 2017 9:26 pm
Nope,
Leafy rails won't bolt to a coily seat, or visa versa, the angle of the ends is different.
You can cut bits of the Leaf rail up & weld to the Coily rail, but it's all a bit of a hack & unlikely to pass any sort of engineering inspection.
Rgs, Michael
Post Posted: Thu Aug 24, 2017 10:59 pm
Ok, against my better judgement, I've just done this - fit Coily seats into a Leafer.
Ended up cutting all the mounting bracketary off the coily rails & when from there.
Didn't want to change the car, so leafy seats can still be bolted in.
The rails on the coily are not even across the car - 20mm difference - means the seats ended up being 20mm taller than they should be - still sort of feels ok & you'd get used to it.
P/side needed rail 'packers' to the tune of 70mm & 90mm to line up with the drivers.
So, doable - yes, if you have a welder & some nouse.
Recommended - no, took hours to sort it & I mean about 8-10.
Would it pass a RWC inspection? probably not if the tester knew what he was looking at.
Rgs, Michael
Users browsing this forum: Google [Bot] and 334 guests
