It is currently Wed Nov 04, 2026 10:38 pm
Vehicle: 95 sj70 and 78 lj81
Post Posted: Tue Mar 01, 2011 2:12 am
The ol zook has now become very noisy with a knocking sound coming from the sump area (or sounds that way). So I pulled the sump off, all the conrods seemed ok so took the crank caps off and found the forward one had a score in it didnt seem bad enough to make the loud knock. Didnt have time to have a real good look as I did this before going to work this morning
So I'll get some new bearings and throw them in tomorrow if I have time.
Any other suggestions or anything I should look at while I'm in there
Post Posted: Tue Mar 01, 2011 2:33 am
get some plastigauge from where you get the bearings, you use this to measure your bearing clearance to see if its ok or not
Post Posted: Tue Mar 01, 2011 2:51 am
Yeah thanks Royce thats a good plan, I'm gonna have a better look tonight as I just price the mains and big ends and they arent cheap. I just wanna keep this engine alive til I go the G16
Vehicle: Nissan
Post Posted: Tue Mar 01, 2011 11:10 am
this may help finding what the noise is...
type: sound: mostly heard during:
Ring noise: high pitched rattel or clicking. acceleration
Piston slap: Hollow, bell-like. cold engine operation and is louder during acceleration
Piston pin knock: sharp metalic rap. hot engine operation at idle
Main bearing noise: Dull, steady knock. louder during acceleration
Rod bearing noise: light tap to heavy nocking or pounding. idle speeds and low load higher speeds
Thrust bearing noise: heavy thumping. irregular sound. may be heard only during acceleration
Tappet noise: light regular clicking. mostly heard during idle
Timing chain noise: severe knocking. increases with increase in engine speed
Pearce-toff Racing
Post Posted: Tue Mar 01, 2011 9:20 pm
Thanks Alex
Was also thinking of the timing chain but I didnt think it would make this sound. Had to work late last night so may get into it today and find the culprit
Vehicle: 1995 Sierra 1.3
Post Posted: Tue Mar 01, 2011 9:26 pm
^ G13's have timing belts.^
Post Posted: Tue Mar 01, 2011 10:32 pm
Thanks Lokidog didnt know that,
I've just pulled the bigends off and found one slightly scored. still dont know if its enough to make the knocking sound. Doesnt appear to be any piston pin slop either.
ah well might just have to change them out and see
Vehicle: Nissan
Post Posted: Wed Mar 02, 2011 4:03 am
yep i just put that there for future reference :)
Pearce-toff Racing
Post Posted: Sun Mar 06, 2011 11:34 pm
Well should of had a better look in the sump. Found a nice piece of piston skirt, oh well anyone gotta a spare second hand piston?
Post Posted: Mon Mar 07, 2011 6:16 am
8O really??
I have some, never looked to hard at em so wouldn't know if they are 1.3, 1.6, but if your going to use old part's, come get em...
Post Posted: Mon Mar 07, 2011 8:58 am
This is the culprit of the knock. Take you up on that offer Stekky.
http://i864.photobucket.com/albums/ab20 ... piston.jpg
Post Posted: Mon Mar 07, 2011 9:10 am
i have 4 brand new pistons here from g13a standard size carton of beer they r yours
Vehicle: Sierra Utey!
Post Posted: Mon Mar 07, 2011 10:51 am
How's the bore look?
My ute..
Post Posted: Mon Mar 07, 2011 10:57 pm
I think I caught it in time crunched, so should survive for a while
Gus I wouldnt like to break up a set, so will try for a good used one first, by the way mines a G13BA so not sure if the pistons are the same
Post Posted: Tue Mar 08, 2011 12:50 am
Well while you have got it pretty much totally apart why not give all the cylinders a quick hone, slap a new set of slugs and ring in?
How many k's on it btw?
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Tue Mar 08, 2011 3:06 am
its done about 200k didnt want to do anything to it or spend anything on it as I want a 1.6. Anyway getting a piston from want33s. and hopefully thats the last I have to spend on it. i did send the hone done just for shits and giggles
Post Posted: Thu Mar 10, 2011 10:00 am
well, thanks to want33 for the piston its all back together and made some noise tonight. yahoo
Users browsing this forum: Google [Bot] and 211 guests
