It is currently Thu Nov 05, 2026 9:06 am
Post Posted: Sat Mar 05, 2011 11:30 pm
After busting up the GV a few weeks ago, I finally got some time to pull it apart.
This is what I found:
[url=Image]Axle 1[/url]
[url=Image]Axle 2[/url]
[url=Image]Axle 3[/url]
Still trying to work out this photobucket thing, so bear with me.
If your not breaking shit, try harder!!!
Post Posted: Sat Mar 05, 2011 11:42 pm
So then I pulled this out and the next few words weren't to pleasant, so I wont post them:
[url=Image]Diff 1[/url]
[url=Image]Diff 2[/url]
[url=Image]Diff 3[/url]
[url=Image]Diff 4[/url]
So can anyone tell me the best place in Brisbane to get this fixed?
I also need somewhere good to have the brake drums machined.
Any other advice??? I'm all ears!
Post Posted: Sat Mar 05, 2011 11:46 pm
:goodjob:
Vehicle: 1.6 SJ80
Post Posted: Sun Mar 06, 2011 12:24 am
Any diff shop will be able to fix it for you, it isn't an overly hard job and any mechanic worth his weight will be able to fix it. Try repco for the drums also, they will machine a flywheel for free if you buy a clutch kit from there so they should be able to do drums aswell.
Post Posted: Sun Mar 06, 2011 7:40 am
Is that a bit missing from the pinion gear. If so id say your up for a new set. Might be easier and cheaper to get a complete ctr.
Post Posted: Sun Mar 06, 2011 8:15 am
Diff and Gearbox Shop, 2/280 Newmarket Rd, Wilston. Ph # 3356 8397
Post Posted: Sun Mar 06, 2011 8:45 am
Thanks Guy's. I just want somewhere that will do the job right after my last experience.
And yes, that is a piece missing off the pinion, I found the piece in the bottom of the drip tray when I dumped the diff oil...that's when the swearing began,
So, Yes...Now looking for a complete diff 5.12 rear.
I have replacement axles, and while I'm at it, I'm going to do wheel bearings, wheel cylinders, brake pads & machine the drums (left & right).
Post Posted: Thu Mar 10, 2011 10:23 pm
Got my bearings today, now, do I need to pack them with grease or just a light smear?
If I need to pack them, is Motorex regular waterproof grease ok to use or do I need to use a particular grease?
Post Posted: Fri Mar 11, 2011 1:26 am
Woo hoo, just found, bought & picked up myself a 12 bolt 5.12 rear diff....
Users browsing this forum: No registered users and 63 guests
