It is currently Wed Nov 04, 2026 7:36 pm
Vehicle: SJ413 WT
Post Posted: Mon Mar 07, 2011 2:32 am
Hey all,
Ever since I did the G13A -> G16B engine conversion on my SJ413 I haven't been able to get into low range 4wd.
My Zook has a 2" lift and it previously had the issue where it'd pop out with a bit of a knock, but I've got a different issue now.
When I put it in either low or neutral, put her in gear and start letting out the clutch I get an awful grinding sound... and no movement. It kind of sounds like 2 cogs trying to sync in together but are just a bit too far apart.
Low range has worked twice since the conversion, but seems to be stuffed now. Hi-Range is fine.
Anyone had a similar issue? I'll probably take it apart and have a look, but if anyone could give me some advice on where to start, that'd be great (I have 0 experience with transfer cases).
Vehicle: SJ413 WT
Post Posted: Mon Mar 07, 2011 2:36 am
I should add - I've done a bit of searching around here and haven't found any similar issues. Plenty of knowledge on low popping out though.
http://www.auszookers.com/index.php?nam ... =low+range
I'm thinking something just isn't properly alligned.
Vehicle: MY2019 Jimny
Post Posted: Mon Mar 07, 2011 4:13 am
You need to enlarge the hole in the floor - It is preventing you getting full into gear.
Vehicle: Work van
Post Posted: Mon Mar 07, 2011 4:31 am
I have the same problem but with high range not lowrange, interested to see your outcome
Swb softie spoa cromo front -50 beadlocks 6.5s :D
Post Posted: Mon Mar 07, 2011 5:53 am
+1.
When you go from 2H to 4H does the lever pop into 4H and hold? The lever itself should snap into position and hold requiring more force to follow through to neutral.
It sounds like there is resistance somewhere stopping the transfer case shifter. Either the boot on the lever itself may need to be cut some to relieve tension or the hole cut bigger.
Remove the boot for starters and give it a go from there.
Vehicle: SJ413 WT
Post Posted: Mon Mar 07, 2011 10:01 am
Roger that. I'll get stuck into it on the weekend. Cheers for the tips guys. I'll let you know how I go.
Users browsing this forum: No registered users and 191 guests
