It is currently Thu Nov 05, 2026 1:57 am
Vehicle: White A/T Jimny
Post Posted: Mon Mar 07, 2011 8:46 am
A few days ago i was driving my g13bb engined jimny over mt glorious, when the engine rapidly overheated. So i pulled over and turned the motor off noticed the coolant was nearly empty (i topped it up only a few weeks ago). Started up fine when it cooled down a bit, limped home and then flushed the radiator, and replaced the coolant (no sign of oil or anything unusual in the coolant). car has not played up since and have tried pushing it pretty hard. Any idea what went wrong the first time and how i could prevent/fix this?
Thanks
Post Posted: Mon Mar 07, 2011 8:57 am
so there was no biuld up of crap in the radiator? did you get it cleaned by a shop or yourself?
if it happens again, i'd get a pro to check the rad out.
also look at your thermostat
Kelvin .: White 2004 Jimny JLX :.
Vehicle: 03 Jimny
Post Posted: Mon Mar 07, 2011 9:08 am
whent the cars running and you have the cap off, does it bubble
could be a broken head gasket or water pump
have you checked if theres no water in ur oil
Post Posted: Mon Mar 07, 2011 9:26 am
no engine should 'use' any coolant, I would be checking it daily until you figure out where its going
Post Posted: Mon Mar 07, 2011 11:13 am
ill hav my mechanic take a look at it, considered whether the gasket is blown however as far as i can tell there is no water in the oil, or smoke
Post Posted: Mon Mar 07, 2011 11:52 am
What year is your jim? The g13bb are prone to cracking heads.
Lil Foot!
http://tiny.cc/gtsw1
Vehicle: WT Tinny, NT lwb, 1L lwb
Post Posted: Mon Mar 07, 2011 12:10 pm
ummm.... maybe a dumb suggestion but.....
radiator cap?
JrZook - Mine only hangs 2.5".
 Profile WWW ICQ YIM
Vehicle: Sierra Utey!
Post Posted: Mon Mar 07, 2011 12:14 pm
That's what I was thinking. Did it overheat and spew out the overflow?
My ute..
Post Posted: Tue Mar 08, 2011 6:56 am
yep
Post Posted: Tue Mar 08, 2011 6:57 am
This is why I keep a spare rad cap in the car!
 Profile WWW ICQ YIM
Post Posted: Tue Mar 08, 2011 7:09 am
Clutch fan.........
Users browsing this forum: No registered users and 318 guests
