It is currently Wed Nov 04, 2026 7:19 pm
Post Posted: Thu Mar 10, 2011 5:40 am
hey auszookers my clutch cable it real stiff and sounds a bit rought when i put th clutch in so whats the best way to make it nice and smooth cheers luke :helloo:
Post Posted: Thu Mar 10, 2011 5:45 am
not sure what its like on a sierra, but i just removed the cover under neath the jimny that exposes the clutch cable, and sprayed a shit load of wd-40 in it.
crude i know, and im sure there is a better way, but it kinda worked for me :lol:
Post Posted: Thu Mar 10, 2011 5:47 am
buy a new 1 mate ,there as cheap as chips and take all of 5 minutes to fit. doubt if it would cost $50.
Post Posted: Thu Mar 10, 2011 5:50 am
Pull it off. Put it on the cloths line and spray WD40 or something like that down from the top till it comes out other end. Then refit.
Or buy a new one. :-)
Post Posted: Thu Mar 10, 2011 6:01 am
yer i think ill try fix it atm as it still works so ill try bruces first then if that gows shit ill buy a newy cheers guys
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Vehicle: LWB Sierra & XL7
Post Posted: Thu Mar 10, 2011 6:33 am
WD40 comes off with water, Lanolin or silicon is some what a bit more water resistant. Look along the cable to see if the casing is broken. But yeah, better off replacing it ohterwise you will be doing it again next month.
'92 Vitara & Camper trailer
Post Posted: Thu Mar 10, 2011 6:36 am
Silicon spray. :wink:
Comes in a can like wd-40. Perfect for stuff like that.
My Grand Vitara
Post Posted: Thu Mar 10, 2011 6:45 am
yeh i will never buy wd-40 i always carry a can of inox and lanox in my zook best shit ever
Post Posted: Thu Mar 10, 2011 6:53 am
WD40 is probably not the best lubricant, i found when i used it to lube my throttle cable it became 10x worse!!!
Spray grease or inox...or whatever i can find floating round the workshop
Post Posted: Thu Mar 10, 2011 7:05 am
I just pull it off one end and squirt silicone spray down it till it comes out the other end, or WD40 if its Bruces :)
Post Posted: Thu Mar 10, 2011 7:17 am
i use chain lube for motorbikes, its a little more thicker than that of silicon sprays, also seems to stick around longer than anything else i have used.
Post Posted: Thu Mar 10, 2011 7:19 am
Springwood suzuki told me once never use WD40/generic it hold's dust/shit.
{bike cables]
I can't remember what they did, but a old fitter I know users mr sheen/generic on big roller doors, which would be a major head- if ya use something that attracts shit.
bye
Post Posted: Thu Mar 10, 2011 8:18 am
{bike cables]
bye
Have a read over your post's, they are hard to understand at the best of times. :evil:
WD40 and the like does attract dust and crap and will wash off alot of anything that works as lube in there. Pushbike chain lube works awesomly for this kind of stuff, motorbike lube is a little thick and can get a bit gummed up.
Post Posted: Thu Mar 10, 2011 8:37 am
you can get graphite powder in a grease version (ie: powder suspended in lube) - its supposed to be slipperier and stick better.
Post Posted: Thu Mar 10, 2011 9:07 am
thankss guys
Post Posted: Thu Mar 10, 2011 10:20 am
I had the same problem, I just pulled back the rubber bit that connects onto the gearbox end a grease it as much as I could
Post Posted: Thu Mar 10, 2011 10:45 am
bingo $15
http://cgi.ebay.com.au/Suzuki-Sierra-Cl ... 1c19fc0c7c
 Profile YIM
Post Posted: Thu Mar 10, 2011 11:30 am
This is what I use with motorbike cables, luber from any bike stop and the graphite spray will have it better than new - mind you you'll pay about $30 for those 2 items :roll:
Users browsing this forum: No registered users and 160 guests
