| Author |
Message |
dp87
Joined: Fri Jun 04, 2010 11:48 am Posts: 174 Location: sydney
 Posted: Tue Apr 05, 2011 8:52 am |
hey guys just wondering how to get those 2 studs out of the gearbox... u know the ones that you replace with the countersunk screws.
looking forward to replies im stuck lol
dp87
 Posted: Tue Apr 05, 2011 8:57 am |
also is that bracket that goes from the intake to the block nessesary... i had to remove it to fit the 1.3 engine mount (im using a baleno g16b)
russty_2008
Joined: Thu Nov 26, 2009 10:30 pm Posts: 435 Location: Gladstone QLD
Vehicle: G16b 83
 Posted: Tue Apr 05, 2011 9:13 am |
I just used multigrips to get mine out not sure bout that bracket I took mine off too
straty
Joined: Tue Aug 10, 2010 12:53 pm Posts: 62 Location: Perth
 Posted: Tue Apr 05, 2011 10:28 am |
put 2 nuts on the thread and lock them together by twisting them in opposite directions. this will allow you to remove or alternatively get a stud remover from repco
steak_knife
 Posted: Tue Apr 05, 2011 11:25 am |
dp87 wrote: also is that bracket that goes from the intake to the block nessesary... i had to remove it to fit the 1.3 engine mount (im using a baleno g16b)
unless you want a busted intake I'd be keeping it of making another less intrusive one..
Fatzook
 Posted: Tue Apr 05, 2011 11:59 am |
steak_knife wrote: dp87 wrote: also is that bracket that goes from the intake to the block nessesary... i had to remove it to fit the 1.3 engine mount (im using a baleno g16b) unless you want a busted intake I'd be keeping it of making another less intrusive one..
X2. The manifold will crack without the brace. Seen it happen many times. Happens to GTI motors too.
dp87
 Posted: Tue Apr 05, 2011 12:11 pm |
ok cheers guys. il have a look for a stud remover. ive already tried using multis but no success. and il have a go at making something up to support the intake
Fatzook
 Posted: Tue Apr 05, 2011 12:16 pm |
dp87 wrote: ok cheers guys. il have a look for a stud remover. ive already tried using multis but no success. and il have a go at making something up to support the intake
Wind a nut onto the stud. Then wind a second nut on and tighten against the first nut. Try to line the edges of the nuts up so that a socket can slide over both nuts. Then use a breaker bar to undo. Might work, but the two nuts will have to be VERY tight against one and another.
dp87
 Posted: Tue Apr 05, 2011 12:30 pm |
il give that a go tomoz before i go out and buy that tool. i im not worried if it doesnt work. more tools in the shed is always a good idea
dp87
 Posted: Wed Apr 06, 2011 12:19 pm |
nup no luck using the nuts to try and get the studs out. i ended up stipping the threads out of the nuts :0
might try making some flat spots on the stud with an angle grinder. then use a shifter to get them out.
shakes
Joined: Sat Apr 10, 2010 11:30 pm Posts: 4895 Location: Northcote
 Posted: Wed Apr 06, 2011 12:25 pm |
dp87 wrote: nup no luck using the nuts to try and get the studs out. i ended up stipping the threads out of the nuts :0
barppp, will more than likely either round off again or snap the stud.. Neither are good outcomes.
If you going to shep it up. at least use a pair of vice grips, or even better some footprints. some rost off ice sprayed on the stud or similar will help too.
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Wed Apr 06, 2011 12:28 pm |
dp87
 Posted: Wed Apr 06, 2011 12:34 pm |
i would weld a nut on but ive got no welding gear. gonna go buy some vice grips tomorrow give that a shot. i have a blow torch would it be safe to heat it up then give it a try?
daisy
Joined: Tue Dec 30, 2008 10:30 pm Posts: 285 Location: Redbank Plains, QLD
 Posted: Wed Apr 06, 2011 7:57 pm |
use a punch and smack it a few times with the hammer and use inox/wd40 and try to drive the thread in a tiny bit then undo it.
one option - grind the thread down to a flat on each side.. only a tiny bit!!!
and a good pair of vise grips with clean sharp jaws - ive seen a LOT that have been rounded and they make the job worse... -
While applying pressure to undo... smack the end with a hammer... it should dislodge any crud.
Heat gun will work as well... apply the heat around the stud hole... not the stud... - it'll melt the loctite thats in there which should make it easier to get out.
stockman
Joined: Thu Nov 05, 2009 10:30 pm Posts: 5319 Location: Canberra
Vehicle: 4wd
 Posted: Wed Apr 06, 2011 10:57 pm |
I tried the old two nut trick too, and with minimum effort stripped the threads.
Welding a small breaker bar onto it made it very easy.
_________________ Watch out or you'll get sued.
dp87
 Posted: Thu Apr 07, 2011 5:21 am |
ok so ive tried everything except for welding now and no success. this is so annoying. got a mate coming around on the weekend to weld something to the studs the same way as stockman did
Ps stockman check ur build thread. got a question for ya
