It is currently Thu Nov 05, 2026 4:51 pm
Post Posted: Tue Apr 05, 2011 12:34 pm
:evil:
i have read this and all the others before anyone says anything.... :wink:
http://www.auszookers.com/index.php?nam ... pic&t=4140
my problem is my petrol guage wont work :roll: i did what it said in the link, when i say it doesnt work..i mean its not correct. right now with a full tank it says half on the dash.
i have a spare fuel sender unit i put in that works perfect but still doesnt read right.... 8O
so whats wrong does anyone know????
Sj80,31 claws, lift, winch, 6.5
Post Posted: Tue Apr 05, 2011 1:06 pm
The probability is you have a bad connection somewhere - the tank not properly grounded, a corroded connection between the gauge and the sender - that sort of stuff.
Disconnect the wire from the tank sender and ground it - do you get a full tank indication now? If not - check the wiring.
Post Posted: Tue Apr 05, 2011 8:28 pm
mine never went to full properly so I couldn't trust it, So I started to measure how many km's I could get from a tank. That is my fuel gauge now.
My Rig --> Click WWW
Post Posted: Tue Apr 05, 2011 10:08 pm
if the wire is earthed out and it shows full on the dash you most likely have some obstuction in the tank or bad eath
if at first you dont succeed-try-try again
Post Posted: Wed Apr 06, 2011 11:56 am
thanks guys ill try earth it :)
Vehicle: Daisy
Post Posted: Wed Apr 06, 2011 12:02 pm
I had the same problem and it was the earth, all I did was run a bit of wire from a bolt on the chassis and put it under one of the bolts that holds the sender in the tank. Fixed straight away.
Oh and that's the second thing I tried, first was testing it while the tank was out but that was only because the tank was out!
Users browsing this forum: AdsBot [Google], Google [Bot] and 51 guests
