It is currently Fri Nov 06, 2026 3:58 pm
Post Posted: Mon Apr 18, 2011 8:08 am
a mate is going efi in his sierra and i may in the future. but lately ive seen a shortage on coily and swb vit tanks, so has anyone looked into efi tanks from donor cars? ive owned a datsun 1200 ute with a ca18det with external pumps and didn't like how noisey it was! now with some mods an r31 tank fitted very easy and was a lot quieter. surely there is a car's efi tank out there that will fit with some mods,maybe some one has come across a tank that might fit? or they think may fit? post up some car makes that you think may be close and ill go down to the wreckers and do some measureing after easter. cheers wayne
Post Posted: Mon Apr 18, 2011 8:34 am
I tuning into this one.
Post Posted: Mon Apr 18, 2011 8:46 am
I actually think CA18zook has some sort of datto tank in his SJ51 with the in tank pump. Not sure if it was from a Skyline or Silvia, but was something of that kind. Maybe try sending him a PM.
Clearance Hole Technology :P
Post Posted: Mon Apr 18, 2011 8:59 am
Take a tape measure to the wrecker's, if you have or can use a welder, make it fit.... :D
Post Posted: Mon Apr 18, 2011 9:17 am
ive thought a lot about doing a drop in swirl pot and efi pump on the sierra tank but really dont want to weld a fuel tank (this will be a last option)
Post Posted: Mon Apr 18, 2011 10:03 am
What model zook? 90's EFI jackaroo tanks fit VERY well under a sierra ute tray. 85L
Post Posted: Mon Apr 18, 2011 11:57 am
Showing my ignorance, how are efi tanks different?
That is bucketload of stupid questions, not cash!
Post Posted: Mon Apr 18, 2011 12:01 pm
They have a large bolted flange on the top that allows a high pressure electric fuel pump to be dropped into the tank, and a "swirl pot" inside the tank that the pumps sits in that holds fuel to stop the pump running dry.
Coil sierras were sold in most other markets as EFI, so they already have the swirl pot and large bolted flange, and an EFI vitara pump arrangement just bolts straight in.
Post Posted: Mon Apr 18, 2011 12:16 pm
Has any one tried to fit a tank out of an ignus yet there small and square like a standard sj tank, havent got one out of a car to measure yet, but surley recon they come close
Suzuki is my way of life.
Vehicle: '96 LWB trayback
Post Posted: Mon Apr 18, 2011 10:42 pm
Can you grab the L x W x H of your tank?
Probably won't fit my tray with all the junk I've got under there, but worth checking before I get a custom one fabbed up.
Post Posted: Mon Apr 18, 2011 10:45 pm
Yeah. Mine takes up ALL the space behind the shocks through to rear crossmember. Sits about 200mm above chassi rail and maybe 50 below, and runs the full width in between the rails. Misses by about 30-40mm.
Post Posted: Tue Apr 19, 2011 6:35 am
the jackaroo tank sounds good for my ute but ill be looking for my mate as well hes got a swb w/t, looks like the ignus is a first measure hopefully i can find something easy to make fit that is still readily available oh and cheers for your input guys any other thoughts?
Post Posted: Tue Apr 19, 2011 8:39 am
I put an ET pulsar fuel pump with custom swirl pot in my standard tank. Just drill a hole with a holesaw. 1 and a half year later and no problems..
Post Posted: Thu Apr 28, 2011 8:28 am
after a quick look today looks like ill be doing a drop in swirl pot and vit pump and welding it in.
Users browsing this forum: Google [Bot] and 115 guests
