It is currently Sun Oct 18, 2026 11:46 pm
lesspostingmorewheeling
Post Posted: Sun May 18, 2008 5:11 am
Are there any companies that makes a light bar for a soft top zook?
Post Posted: Sun May 18, 2008 11:54 am
not that I know of, not a lot of fancy stuff for sierras cause as soon as a company makes something we all go geez look at that what a rip off and then go and copy it :wink:
Vehicle: 75 Cruiser
Post Posted: Sun May 18, 2008 1:06 pm
i've seen a couple ones that look good and are simple.
You could bolt a straight bar across the top of the windscreen on to those rubber stopper thingys.
or if you can bend tube, you can make one that bolts on to your door hinges and goes up and follows the curve of your windscreen.
Post Posted: Sun May 18, 2008 9:33 pm
Do you mean a spotlight bar or a lightbar like the taxi's have..>?
Thanks,
Chris
http://www.nbs4x4club.com
Post Posted: Mon May 19, 2008 1:23 am
i was thinking of something that could be mounted to the factory rollbar over the soft top to mount a couple spotties to
Post Posted: Mon May 19, 2008 1:43 am
There is a problem with this bar...
When i have the lights on, its only really good for spread over short distance, because the lights reflect of my bonnet and window!
It makes every spot of dust light up so its like glare..
I was gonna make like a visor under them but maybe later..
The bar is full custom(i made it) as i was wondering what went in the holes in the window? Until i made it then saw others with the rubber bumpstoppers, which id never use anyway..
The holes in the windo are drilled right through, with stainless bolts and a slice of push bike tube rubber inbetween. Pretty much angle cut to size and 25x25 rhs ,capped ends and spaced holes 4 spotties, the wiring is then run under, inbetween the vinal slot and the button and tied down the pillar til in the dash. Hard to explain
Later on i may just get the bikini so its like a ute, then put the bar over the roof pillar, like what u want, but i may go the fastback top option
Post Posted: Mon May 19, 2008 2:28 am
mounting them over the roof pillar should stop the reflection problem i've been thinking and if i could weld i'd make sort of an outer roll bar that mounts where those plastic panels are at the bottom of the pillar then then i could use the full top
Post Posted: Mon May 19, 2008 2:32 am
Thats not a bad idea! Will keep that in my thoughts. Depends on the legal issues too, some cops with think its an exo cage. Which if im gonna do the light bar i may as well make an exo :lol:
Where's your location mike?
Post Posted: Mon May 19, 2008 2:45 am
or you could make a set of roof racks like the ones calmini make
i'm from a little island called tasmania you've probably never heard of it
Vehicle: 75 Cruiser
Post Posted: Mon May 19, 2008 10:48 am
probably be ok on the B pillar, but you'd have to keep your soft top on so you didn't get glare back from the windscreen?, but i guess you'd keep the soft top on in tasmania anyway ? :)
Vehicle: Zookless
Post Posted: Mon May 19, 2008 4:33 pm
Here's a link to a dude on outers who is making a bar similar to what you are describing. http://www.outerlimits4x4.com/ftopic136048.php
A couple of years ago, I drove up to Ben Lomond with the roof off - it was a beautiful day in Launceston. When I got up there it started snowing. 8O
By the time I had the roof on I was freezing, and trying to get the press-studs on was just painful. :lol:
Post Posted: Mon May 19, 2008 11:33 pm
the roof doesn't come off that often because its too much work to get it back on
Post Posted: Mon May 19, 2008 11:35 pm
i didn't think there was such thing as nice day in launceston :lol:
Post Posted: Tue May 20, 2008 9:38 pm
here is one i made a while ago.
after the test fit we painted it black.
It mounts to where the bonnet stopper go
ill try find some more pics
84 lwb sierra, 30x9.5, 2 inch lift
http://www.aus
Users browsing this forum: Google [Bot] and 451 guests
