Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
weaves
Joined: Fri Mar 21, 2008 10:30 pm Posts: 1564 Location: Newcastle
 Posted: Wed Apr 27, 2011 6:27 am |
Hey guys,
I'm doing the NT to WT swap, and i have to run the two seperate brake lines to each brake cylinder on the rear, i've decided to just make new hard lines across the diff.
I have the double flaring tool, bender and cutter, i just don't know what size fitting is needed to fit into the flexible hose, and the brake cylinders, can anyone help me out with these sizings?
weaves
_________________ I'm Weaver & i like beer, boobs, cars and stickers
tmb99
Joined: Tue Mar 09, 2010 10:30 pm Posts: 330 Location: Brisvages
 Posted: Wed Apr 27, 2011 7:16 am |
I was just reading this last night! Got some made the other day my invoice says 10mm with 1mm seat... I'll have a look when I get home see if it has any other info.
BenT
Joined: Sun Nov 16, 2008 10:30 pm Posts: 208 Location: Nelson, NZ
Vehicle: 85 SJ413
 Posted: Wed Apr 27, 2011 8:46 am |
Yep, they are M10x1
_________________ WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Wed Apr 27, 2011 9:29 am |
PS: aint you running the DS flexy line into the DS drum, then across the axle? from the flexy into a T-piece, then going either way? you would need another bleeding nipple if you do it the second way...
weaves
 Posted: Wed Apr 27, 2011 9:58 am |
mine has 2 bleed nipples as it is, it has 2 flex lines running from the chassis to the diff, then two hard lines running to each side, bleed nipples on both sides.
Thanks for the sizing guys, saves me having to pull it all apart before ordering parts.
weaves
31zook
 Posted: Wed Apr 27, 2011 9:59 am |
doh. ok, fair enough
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: No registered users and 104 guests
