It is currently Fri Nov 06, 2026 9:45 pm
Post Posted: Wed Apr 27, 2011 6:27 am
Hey guys,
I'm doing the NT to WT swap, and i have to run the two seperate brake lines to each brake cylinder on the rear, i've decided to just make new hard lines across the diff.
I have the double flaring tool, bender and cutter, i just don't know what size fitting is needed to fit into the flexible hose, and the brake cylinders, can anyone help me out with these sizings?
weaves
Post Posted: Wed Apr 27, 2011 7:16 am
I was just reading this last night! Got some made the other day my invoice says 10mm with 1mm seat... I'll have a look when I get home see if it has any other info.
Vehicle: 85 SJ413
Post Posted: Wed Apr 27, 2011 8:46 am
Yep, they are M10x1
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Post Posted: Wed Apr 27, 2011 9:29 am
PS: aint you running the DS flexy line into the DS drum, then across the axle? from the flexy into a T-piece, then going either way? you would need another bleeding nipple if you do it the second way...
Post Posted: Wed Apr 27, 2011 9:58 am
mine has 2 bleed nipples as it is, it has 2 flex lines running from the chassis to the diff, then two hard lines running to each side, bleed nipples on both sides.
Thanks for the sizing guys, saves me having to pull it all apart before ordering parts.
weaves
Post Posted: Wed Apr 27, 2011 9:59 am
doh. ok, fair enough :D
Users browsing this forum: No registered users and 88 guests
