It is currently Sat Aug 01, 2026 7:11 am
Post Posted: Sun May 08, 2011 1:26 am
My LJ50 3 cyl 2stroke motor has a collapsed con-rod big end bearing - Can any engine re-builder do these or do I have to go to a 2 stroke specialist?
Recommendations?
Tony
Vehicle: LJ20 LJ50
Post Posted: Sun May 08, 2011 1:31 am
Take it to a motor bike engine rebuilder.
The bearings and rods are still available brand new from suzuki and if you get a really good bike shop you can get the crank better than what is was from the factory.
The whole crankshaft is just pressed together the trick is puting back to gether exactly right. If its not in the right spot when its put back to gether then it your engly cylce will be out.
Just find an awesome 2 stroke engine rebuilder. Maybe Ball knows someone close to you who would be good.
Camels have nice toes
Post Posted: Sun May 08, 2011 10:43 pm
Can anyone recommend somewhere that can do this? Preferably in NSW?
Tony
Post Posted: Mon May 09, 2011 2:32 am
I don't know anywhere off the top of my head in NSW but will have a dig in my contact list and see if I can find someone.
Vehicle: Suzuki LJ50 & LJ81
Post Posted: Mon May 09, 2011 2:34 am
A mate is getting his crank rebuilt in Sydney at the moment. They are trying to locate the seals and bearing, although it is looking like the seals are not available. The guy doing the work is a bike repairer. I will let you know when it is done and how it went, just to make sure the guy knows what he is doing. I am getting a rattle in my 50, so may need a rebuild soon too.
Post Posted: Mon May 09, 2011 3:20 am
Thanks Ball - I guess anywhere will do if I have to send it somewhere to far to drive too.
That would be real good Fifty - I guess the seals you are talking about are the cylinder to cylinder mains seals
Post Posted: Mon May 09, 2011 4:06 am
Yes, the seals between the chambers. The seals on each end are just common lip seals. He got the crank last week, so should have a result of some sort this week.
Post Posted: Mon May 09, 2011 9:09 am
Keen to hear how it comes out
Users browsing this forum: Google [Bot] and 76 guests
