It is currently Mon Oct 19, 2026 3:11 am
Post Posted: Wed May 28, 2008 11:44 pm
Hey
I just installed my new clutch cable and it is way to tight!
I think this is due to the pedal adjustment.
Any ideas?
Nissan Recover Vehicle
Post Posted: Wed May 28, 2008 11:55 pm
dont touch the pedal!!!!!!!!!!!!!!!!!!!!!!1
loosen the cable at the gearbox end, the big knob thing on the end screws in and out, you want the slightest amount of freeplay int he clutch arm
Post Posted: Thu May 29, 2008 12:00 am
I adjusted my cable to all kinds of different ways and is still way to tight!
PS why does the Clutch Pedal have "Switch" on it?
Post Posted: Thu May 29, 2008 12:02 am
got an aftermarket clutch?
Post Posted: Thu May 29, 2008 12:03 am
Mate i have no idea, Dont think soo , my Suzuki Service Manual says i need to connect my " Ohm meter " up to the bedal p4 i adjust, im like WTF
Post Posted: Thu May 29, 2008 12:14 am
you can adjust the bracket on teh engine mount too, screw the nute further up the cable to get more slack, or screw the end bit out on teh cable to get more slack
Post Posted: Thu May 29, 2008 12:18 am
don't worry bout that...is just a gearbox emmisions switch. if you had probs with the first cable, and now you have probs with the second as in bein too hard on the foot... i think you have clutch issues.
Post Posted: Thu May 29, 2008 12:20 am
K ill explain what happens. If i make it slack like u recommend ( which i have already tried) all that happens is the where the clutch grabs changes forceing me to push the pedal way to far in and when it goes in a fare way it become hard to push for the last 10 CM this is just making it arkward. When i tighten it , it just changes the friction point earlier adn then become stiff hard to push in!
Sorry if its confusing but i cant really explain it :(
Post Posted: Thu May 29, 2008 12:24 am
the more slack you have the closer to the floor it will bite and the less the higher it will bite but you can also push the pressure plate too far and risk teh throwout bearing running all the time and seizing
just set it so you have about 2mm play at the end of the arm on the box and live with it :wink:, clutch pedals are supposed to go to the floor
Post Posted: Thu May 29, 2008 12:25 am
seen it many times before...pressure plate is full of shit or nackered.
Post Posted: Thu May 29, 2008 12:39 am
The Clutch is fine its just the tension of whateva. I had a look under the pedal just then and there is a little pin that rides the pedal and it is making the pressure increase therefore harder to push down/
Post Posted: Thu May 29, 2008 12:54 am
if it all worked before and all you changed is the clutch cable then the problem is adjustment of the cable none of the pedal stops
Post Posted: Thu May 29, 2008 1:23 am
K cheers ill have another look when i get time.
So what should i check to make it easier to push in?
Post Posted: Thu May 29, 2008 1:25 am
was it easy before? like joe said its probably full of crud, though clutches are supposed to be heavy at the top and then get lighter, perhaps your old cable made it heavy all the way so you didnt notice?
Post Posted: Thu May 29, 2008 2:27 am
nah my old one was light the whole way this one is SOOO HARD the whole way and i am not happy with it at all. i like the light clutches when ya push them in nice and easy.
Post Posted: Thu May 29, 2008 1:58 pm
i had a problem with my vitaras cable clutch and got it replaced (the real problem was the firewall where the clutch went through) and my mechanic said to me that if the pedal feel gets harder, then i have clutch problems too.
if this is a common problem, how weak is the clutch to begin with, and what is a good replacement?
Post Posted: Thu May 29, 2008 5:31 pm
It's not really a weakness thing. When they get lots of dust and mud in the bellhousing everything tends to be harder to move. Release bearing, pressure plate etc.
We use the Exedy clutches in our rental cars and don't have too many issues with them.
Post Posted: Thu May 29, 2008 8:58 pm
meh i dunno booked it into an auto electrician today cause i got a wiring problem as well. DAM U ZOOK
Post Posted: Fri May 30, 2008 12:46 am
people....always and always use exidy clucthes, the rest are crap!
Post Posted: Fri May 30, 2008 10:20 pm
joeblow wrote:
people....always and always use exedy clutches, the rest are crap!
Hahahahahahahahahahaha!!!!!
Post Posted: Sat May 31, 2008 5:53 am
Havent fixed clutch but auto mechanic fixed dodgy earth wire and the alternator was F@#ked
Users browsing this forum: No registered users and 241 guests
