It is currently Sun Oct 18, 2026 8:34 pm
Post Posted: Sat May 31, 2008 2:46 pm
how you going pples, you know how some pple have done the 3/4 elliptic rear?? has anyone done it to the front? if not! why. also is this a leagle modification
thanks
spoa, lux diffs, 2inch suspension, 2inch body, 1.6
Post Posted: Sat May 31, 2008 7:24 pm
Probably, but that doesn't mean it's a good idea.
norm wrote:
if not! why
Leverage. The front end would have a tendancy to sway side-to-side because the front end of the springs is no longer fixed to the chassis, but to a length of spring, and that is going to flex and intoduce (more!) movement into the whole assembly. Onroad, that would make handling atrocious. Offroad the tyres would end up pushing the axle to the side instead of steering. I can't think of anything that would make this a good choice!
I've heard of it being engineered for REAR applications (but pins have to be fitted to lockout the extra flex for onroad). I can't imagine any engineer in his right mind passing it in a front end application.
IMO you should go with some longer leaves. It's been done plenty of times and proven to work.
Post Posted: Sun Jun 01, 2008 1:45 am
It would screw with you steering big time, most Sierra's tend to travel pretty good on the front just have to get the rear to work.
Users browsing this forum: No registered users and 246 guests
