It is currently Mon Oct 19, 2026 8:52 pm
Post Posted: Mon Jun 02, 2008 10:35 pm
Well here is what is happening,
i have a 1995 vitara fuel injected, i went 4wding about 1 month ago and still hadnt got to giving my engine a proper clean up, so sat i got the hose out and soap and washed my engine and engine bay and all sourrnding parts. now i parked it in the shed and left it there overnight, i drove sunday morning and when it got warm it started spitting and carrying on.
it would only when i put the throttle on and as soon as it got over about 2500 revs it stopped spitting and revved all the way up the rev range fine.
at idle she idles a little bit rough with the occasional spit. a friend thinks that i have got water in the distributer so i got wd-40 and sprayed the shit outta it and sprayed all other electrical components that i know of.
If anyone has any idea on what could be the problem i would love to hear from you.
Craig
Post Posted: Mon Jun 02, 2008 10:40 pm
did you wipe the wd40? it conducts electricity
check for water in the plug holes as well, even water in the intake
Post Posted: Mon Jun 02, 2008 10:54 pm
definately no water in the air-intake, filter was little bit dirty so blew it out, and no difference, the weird thing is, its when the car heats up, car runs like it is suppose to until it heats up?
Post Posted: Mon Jun 02, 2008 10:57 pm
sounds like a spark thing, pull all your leads out and check they are dry
Post Posted: Mon Jun 02, 2008 11:06 pm
so i just pull the black leads going to the top of the block straight up, is there anything else i have to do?
Post Posted: Mon Jun 02, 2008 11:12 pm
yeah stick an air blower down the holes to get rid of the water
check the cap ends too
Post Posted: Mon Jun 02, 2008 11:15 pm
ok i will get my bros cordless hitachi air blower jam that in there then give it a good blow and than spray it wit wd40 again what you think about that big boy
Post Posted: Mon Jun 02, 2008 11:23 pm
NO WD40 ITS THE DEVIL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
throw the tin of the shit as bar as you can
just get whatever int here to blow the water out, why replace water with bloody oil from a tin
Post Posted: Mon Jun 02, 2008 11:26 pm
BWHAHAHAHAHAHHAHAHAAHHAAH. He called you a big boy Royce. Shit, that's sooooooooooooo funny
Post Posted: Mon Jun 02, 2008 11:29 pm
Hey big boy, how ya going :no:
Yep :gross: that tin of WD40 far away from there. AIR is your friend :wink:
watch it fatass or there will be bannings all round
Post Posted: Mon Jun 02, 2008 11:31 pm
:comeon: bring it on.
Keep that up and I'll tell all on zookes site that it's a :happybirthday: to you this weekend :wink:
Post Posted: Tue Jun 03, 2008 12:03 am
Post Posted: Tue Jun 03, 2008 12:15 am
right thats it I am renaming this place ausmini, everybody get out :rambo:
Post Posted: Tue Jun 03, 2008 1:23 am
HEYYYYYYYYY, That's my hammer, my shed. Looks like MY air hose as well.
GET OUT OF MY SHED
God you are one ugly bastard :gross:
Post Posted: Wed Jun 04, 2008 12:30 am
Hmmmmmm Royce is a big boy ............... They have been peaking around the corner at you again Royce,
It's ok mate you will make some girl happy
Steve W
Post Posted: Wed Jun 04, 2008 12:43 am
Oh as for the car at the front of the motor there is a plug (White)on the L/H side looking from the front of the car sitting vertical with 9 holes with wires going into it. 2or 3 of them do not have wires in them, seal them up and seal the others up as well ( Liquid Tape )
Next in the dark remove the coil lead from the coil and crank it over and see if the coil shorts out everywhere. This happened to Stretch and what had happened was the lead was never pushed all the way in and burnt the backerlight from inside the coil entrance, chaec also if the lead into the coil is black as this will tell you it is jumping a spark.
Could also spray the electrics with a sm squirter bottle ( Use Mist)and see what happenes while the car is running.
Steve W
Users browsing this forum: No registered users and 253 guests
