It is currently Fri Nov 06, 2026 8:34 pm
Post Posted: Tue May 31, 2011 10:07 pm
G'day :helloo:
Anyone know what size belt i will need to hook up my p/s?
It's a 96 swb efi vitara JX with NO a/c
I'm bolting it all in tomorrow so i wanted to have all the parts here ready to go :D
Cheers Joe
Post Posted: Tue May 31, 2011 11:46 pm
I don't know if they are the same, but I have a 92 8v carby, and if all is standard they run a 4pk 810 for alternator and p/steer.
pete
Post Posted: Tue May 31, 2011 11:56 pm
Get some string, loop the string around the pulleys with the tensioner about 1/4 tension position, measure length of string needed, write down measurement, go shopping with measurement with thought of single v or 4mulitv in supercrap or similar, choose checkout chick with boobs.
With the tensioner in the 1/4 tension position, its so if you buy an exact size belt, you can get it on and off. I did mine with no tension, it was a pain because i couldnt move the tensioner to get some slack. I ended up driving it on with a screwdriver..
Vehicle: '96 LWB trayback
Post Posted: Tue May 31, 2011 11:57 pm
pete
:goodjob: My G16b bottom end with g16a power steering ran 4pk 810mm for both alt/ps.
Post Posted: Wed Jun 01, 2011 12:01 am
Come to think of it.. mine did too.. vit ps on baleno 1.6 efi. My ps bracket i had to mod after, so thats prob why it was tight.
Post Posted: Wed Jun 01, 2011 1:03 am
My alt belt is a 800 :?
Post Posted: Wed Jun 01, 2011 1:06 am
10mm longer is not much.. Means the tensioner will only be moved 5mm more.
Post Posted: Wed Jun 01, 2011 1:11 am
Ok ill measure with string first and go that way, ill update in here what size i went with :)
Thanks people :helloo:
Post Posted: Wed Jun 01, 2011 1:12 am
Armsup
Post Posted: Wed Jun 01, 2011 3:03 am
both mine are 4pk800s for alt and p/s on a g16b in my sierra
Post Posted: Wed Jun 01, 2011 7:18 am
So's both of mine..... :helloo:
Post Posted: Wed Jun 01, 2011 8:28 am
As in att & p/s on Sully or att on Sully and att on the dd?
:helloo:
Post Posted: Wed Jun 01, 2011 8:31 am
:helloo:
Alt w/pump & p/s belt's the same size, I only carry one spare belt that way & that's what fit's.........
:helloo: Joe, what do ya know!!! :D
Post Posted: Wed Jun 01, 2011 8:35 am
I know a bit about power steering belts now :D
Cheers guys :helloo:
Post Posted: Wed Jun 01, 2011 8:40 am
If the p/s pump if it was fitted with a/c will be solid mounted, but you can move one bolt & turn the bracket into it's own adjuster.......
You know more now...... :P
Post Posted: Wed Jun 01, 2011 8:43 am
I was looking at how that works today :wink:
Post Posted: Wed Jun 01, 2011 8:45 am
:P
I was part way through making an adjuster when I spotted that.... :lol:
Post Posted: Thu Jun 02, 2011 7:03 am
I ended up using a 800 for p/s aswell :D
Users browsing this forum: Baz89, Google [Bot] and 95 guests
