| Author |
Message |
TryHard
Joined: Thu May 13, 2010 1:49 am Posts: 1041 Location: Perth
 Posted: Thu Jun 02, 2011 7:12 am |
ok i know theres alot of different ways of doing RUF extend shackles , missing links shakles , extending the chassis out .. now my question is what set up are u using what have u tryed and what works and what doesnt .. any info would be great thanks im mainly intressed
JrZook
Joined: Tue Aug 08, 2006 11:30 pm Posts: 5517 Location: Holland Park
 Posted: Thu Jun 02, 2011 8:10 am |
Stock shackles, front and rear hangers moved accordingly to accommodate the spring and move the front diff ~10mm forward (30"tires), full custom springs and koni shocks.
Quite stable off road, good road manners with the swaybar in. Rides pretty nice too!
Some info here: http://www.auszookers.com/index.php?nam ... &start=120
_________________ Lil Foot!
http://tiny.cc/gtsw1
TryHard
 Posted: Thu Jun 02, 2011 8:22 am |
JrZook wrote: Stock shackles, front and rear hangers moved accordingly to accommodate the spring and move the front diff ~10mm forward (30"tires), full custom springs and koni shocks. Quite stable off road, good road manners with the swaybar in. Rides pretty nice too! Some info here: http://www.auszookers.com/index.php?nam ... &start=120
Thanks for the info .. but i do not want to move the hangers everything Pref needs to stay the way it is .. and i want to run RUF using longer shakles maby ..
taszook
Joined: Wed Jul 07, 2010 9:14 am Posts: 173 Location: Tasmania
 Posted: Thu Jun 02, 2011 8:38 am |
i was reading the other day about using stock rears in the front and re-drilling the rear spring hanger thing back 25mm and up 10mm, then run longer shackles, cant remember the size off the top of my head tho... 70mm sound right? or is that stock size?
TryHard
 Posted: Thu Jun 02, 2011 8:39 am |
taszook wrote: i was reading the other day about using stock rears in the front and re-drilling the rear spring hanger thing back 25mm and up 10mm, then run longer shackles, cant remember the size off the top of my head tho... 70mm sound right? or is that stock size?
ya stock size are like 1 inch shakles
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Thu Jun 02, 2011 10:01 am |
TryHard wrote: JrZook wrote: Stock shackles, front and rear hangers moved accordingly to accommodate the spring and move the front diff ~10mm forward (30"tires), full custom springs and koni shocks. Quite stable off road, good road manners with the swaybar in. Rides pretty nice too! Some info here: http://www.auszookers.com/index.php?nam ... &start=120Thanks for the info .. but i do not want to move the hangers everything Pref needs to stay the way it is .. and i want to run RUF using longer shakles maby ..
JrZook is spot on, my advice is if you don't want to move mounts forget about RUF because you are wasting your time.
2stroker
 Posted: Thu Jun 02, 2011 10:03 am |
Yep this has been done in the past, it is a "rough" not a "RUF"
2stroker
 Posted: Thu Jun 02, 2011 10:05 am |
TryHard wrote: taszook wrote: i was reading the other day about using stock rears in the front and re-drilling the rear spring hanger thing back 25mm and up 10mm, then run longer shackles, cant remember the size off the top of my head tho... 70mm sound right? or is that stock size? ya stock size are like 1 inch shakles
Your tape measure is faulty, standard shackles are 70mm, 1inch is 25mm
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
taszook
 Posted: Thu Jun 02, 2011 10:21 am |
it would be a lot safer than me welding chassis extensions on then bolting my springs onto them O.o they would snap off coming out my driveway
Nagz
Joined: Tue Nov 02, 2010 4:22 am Posts: 231 Location: Sydney
 Posted: Thu Jun 02, 2011 11:05 am |
taszook wrote: it would be a lot safer than me welding chassis extensions on then bolting my springs onto them O.o they would snap off coming out my driveway
If thats the case then i would think that maybe you would be better off getting a professional to do it for you. Do it once do it right im sure you would rather spend $300 bucks rather than kill some poor person when ya rig falls apart because you wanted to save a bit of cash. Just think about it before doing some dodgy setup it will 95% of the time come back to bit ya !!!
Thats my 2 cents.
taszook
 Posted: Thu Jun 02, 2011 11:21 am |
I dont think I can even be bothered doing it. Dont think the re drill with stock rear is worth the effort. I know boiler makers but I think extending the chassis is dodgy anyways, dont like the idea personally
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Thu Jun 02, 2011 11:26 am |
TryHard
 Posted: Thu Jun 02, 2011 11:27 am |
ok sounds like il do chassie extention  no lazymans way
taszook
 Posted: Thu Jun 02, 2011 11:35 am |
Dodgy was prob the wrong word. I just dont liked the idea, maybe when I think of welding i just see my welding haha. And that is the beefiest extention I have seen by far
whincup
Joined: Sat Apr 17, 2010 11:30 pm Posts: 1588 Location: Gracemere, QLD
Vehicle: '94 suzuki maruti
 Posted: Thu Jun 02, 2011 11:37 am |
any idea how much it would cost for a professional to do a PROPER chassis extension with spring hangers moved? assuming i already had the springs, shocks, shackles etc, just the cost for labor and materials?
93zook
Joined: Wed May 27, 2009 11:30 pm Posts: 699 Location: perth
 Posted: Thu Jun 02, 2011 12:01 pm |
2stroker wrote: TryHard wrote: JrZook wrote: Stock shackles, front and rear hangers moved accordingly to accommodate the spring and move the front diff ~10mm forward (30"tires), full custom springs and koni shocks. Quite stable off road, good road manners with the swaybar in. Rides pretty nice too! Some info here: http://www.auszookers.com/index.php?nam ... &start=120Thanks for the info .. but i do not want to move the hangers everything Pref needs to stay the way it is .. and i want to run RUF using longer shakles maby .. JrZook is spot on, my advice is if you don't want to move mounts forget about RUF because you are wasting your time.
why do you think this?
rick1970
Joined: Sun Jul 04, 2010 9:39 pm Posts: 303 Location: Dungowan
 Posted: Thu Jun 02, 2011 6:18 pm |
Just put LJ rear springs (same length as Sierra rears) in the front of my LWB. 50mm chassis extension (30 would have been ok), front mount moved forward 30mm, origional rear mount position, 90mm long shackles.
Front end flex is heaps better, ride is smoother and onroad handling is better.
