It is currently Fri Nov 06, 2026 6:43 pm
Vehicle: Suzuki Vitara
Post Posted: Wed Jun 15, 2011 1:17 am
Hey there! Does anyone else think that this is a little suspect? I took my vehicle down to Kmart Auto this morning to have the tires rotated. When I picked the vehicle up the mechanic informed me that he had had trouble starting my vehicle due to the solenoid on the starter motor. After I had payed for the work I went to leave, however I was unable to start my car. I have never had a trouble starting the vehicle up until this point. The vehicle is a SV420. With a tap of the solenoid, I was able to get it going. Do you think it is just bad luck or does anyone else think this is a little suspect? I am now looking at around $250 to have the starter out and the brushes replaced. Thanks for your time, rwicks10
Post Posted: Wed Jun 15, 2011 1:19 am
If your mechanically minded the bushes cost around $11 for my brothers hilux starter, we pulled it apart and replaced them, piece of cake.
My Rig --> Click WWW
Vehicle: 91 WT 1.6EFI
Post Posted: Wed Jun 15, 2011 3:05 am
just open it up, use some wd40 and a light sanding. grease the arm from the solenoid into the starter motor and you should be fine. or as said above, there's nothing complicated inside.
Post Posted: Wed Jun 15, 2011 3:08 am
Solenoid of starter has no bushes....
OP just do as Rossco suggested.
Lil Foot!
http://tiny.cc/gtsw1
Vehicle: 4wd
This may be of use: http://www.auszookers.com/index.php?nam ... ic&t=21965
Watch out or you'll get sued.
Post Posted: Wed Jun 15, 2011 3:19 am
brushes?
Post Posted: Wed Jun 15, 2011 3:35 am
brushes?
Brushes are in the actual starter motor not the solenoid.
Lil Foot!
Post Posted: Wed Jun 15, 2011 4:14 am
o my bad, dude said it would cost him $250 to have starter pulled out and brushes replaced and I remember replacing my brothers brushes for $11.
must have read it wrong
Post Posted: Wed Jun 15, 2011 4:35 am
If he went to Kmart auto to get his tyres rotated, I am not sure if he would have the mechanical ability to pull down a starter motor, regardless of how easy we know it is. (no offence)
Starters can start playing up in an instant, I doubt they buggered around with anythning on you.
Post Posted: Wed Jun 15, 2011 4:41 am
check its not something stupid like a loose or dirty terminal before you go pulling stuff apart
Post Posted: Thu Jun 16, 2011 12:13 am
well I don't know about you but whenever I put tyres on the front of my car I make sure they are balanced correctly.
and I certainty don't have a wheel balance machine at home
Post Posted: Thu Jun 16, 2011 3:37 am
I was assuming that the tyre including rim was swapped, not removing tyre from rim, thus no need for rebalancing...
Post Posted: Thu Jun 16, 2011 6:47 am
don't do that, just pull it apart :D
Post Posted: Fri Jun 17, 2011 9:59 am
Thanks for the assistance their! I ended up getting the starter rebuilt by a local auto electrician. Cost a little, however the rebuild was significantly was cheaper than purchasing a new starter. All is good now, and it is back on the road. Cheers, rwicks10.
Users browsing this forum: Google [Bot] and 53 guests
