It is currently Sat Nov 07, 2026 12:08 am
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
Vehicle: 4wd
Post Posted: Sun Jul 17, 2011 12:21 pm
Just came across this and I have never seen one before.
http://i223.photobucket.com/albums/dd20 ... 6375_g.jpgImage
I can't think of a down side.
-Can be kept out of the weather.
-Could be set up so the hitch comes through the standard bar and could be covered by the number plate when not in use.
Does anyone run one of these?
Watch out or you'll get sued.
Vehicle: 92 Suzuki Sierra
Post Posted: Sun Jul 17, 2011 1:17 pm
i guess with the limited real estate of a zook you don't really want extra things in the tub?
i am STILL kicking myself for not getting a winch that was mounted inside an oem bumper. So tidy and out of the way
-Santos
Post Posted: Sun Jul 17, 2011 1:29 pm
The weAther argument is a little void. Most winches are pretty well sealed.
You have extra connections to fail. More space taken up inside the car. Would be a pain to lug through a bog hole. Slot in, connect up, then pack away again because its acting as a grader blade.
Good to winch from behind. But a couple of snatch blocks and another car or some trees will sort that out.
Possibly good for agriculture but I cant see a real benefit over a winch fitted to a well thought out bar.
Post Posted: Sun Jul 17, 2011 10:15 pm
Think of this.
When do you need to use a winch?
You've got it bogged to the chassis rails. How easy is it going to be to hook this thing up?
You're on a steep hill with a step up. Its not going to be fun lugging it around safely trying to hook it up either.
I had though about this setup before too but the only time you need a winch is usually not the most convenient position to install it. JMHO.
Post Posted: Sun Jul 17, 2011 11:04 pm
If your considering on of these I think you would be much better off with a good hand winch
Post Posted: Sun Jul 17, 2011 11:07 pm
The only good hand winch is one somebody else is pumping the handle on :)
I liked the one some mob use to make that was teh winch bolted to a plate with holes to shcakle it via straps to whatever you are winching, combined with one of them compact tigerz winches it would be a useful tool
Post Posted: Sun Jul 17, 2011 11:17 pm
i would set fire to a car and walk home rather then use a hand winch. fucken horrible things.
on of the problems with sticking a winch on ya tow bar is getting the power to it.
big winches need 450+ amps and that is some serious cable. i have a 175amp anderson plug on the back of my LWB
and using 32mm2 cable i reckon i get a bit off voltage drop.
Vehicle: 4wd
Post Posted: Mon Jul 18, 2011 3:22 am
I'd like to keep the stock front bar, but I don't think there would be room for a decent size winch behind there.
LTM21 wrote:
Think of this.
My other option would be a Tirfor, but it would be exactly the same as circumstances.
Post Posted: Mon Jul 18, 2011 3:29 am
Want33's had a decent winch behind his stock front bar. Looked neat.
Vehicle: 4wd
Post Posted: Mon Jul 18, 2011 3:33 am
Thanks T'bo thats what I want to hear.
Going to look for some pics. 4000lb should be plenty for a Sierra?
Vehicle: 4wd
Post Posted: Mon Jul 18, 2011 3:43 am
I mean 6000lb. Says it's good for a vechicle upto 2720kg's.
Its 31kg with a steel rope, so a nylon would bring it down another couple of kilos.
i'd be looking at Dank's stumpy 6000lb
Post Posted: Mon Jul 18, 2011 4:03 am
That's what I'll be getting when I've got the funds. And it doesnt look too tight to squeeze a winch in there... Would be tricker to make the cradle then mount the stock bar over top of it. I shouldn't speak because I've never tried though.
Post Posted: Mon Jul 18, 2011 7:09 am
photos?
EDIT: Found it
Looks like it doubles as a bullbar
-Santos
Post Posted: Mon Jul 18, 2011 9:34 am
oh looks like the clip is cut though..
Vehicle: 4wd
Post Posted: Mon Jul 18, 2011 10:24 am
I still like the idea of the portable. Bracket flushmounted into the bar covered by the front plate.
Would be pesy to have one winch set up for two cars.
Has anyone used a winch but not had it mounted. Rope to the tree and then whinch with a couple of straps to recovery points.
Post Posted: Mon Jul 18, 2011 10:43 am
Powering the thing will be a mess. Winch cable, 3 elec cables..
Vehicle: 1992 sierra
Post Posted: Mon Jul 18, 2011 2:25 pm
Considering the trip you're about to take, big call.
Agreed, human operated winches are an absolute bastard. Hard fucking work.
You do what you have to do though 8)
Post Posted: Mon Jul 18, 2011 2:52 pm
i have more then enough winch on the front off my car :wink:
Post Posted: Mon Jul 18, 2011 8:31 pm
I didnt say I would own one :lol: :lol:
I'd rather die in the bush than winch myself by hand out of anything :wink:
I do however think it solves the problem of a movable winch
Post Posted: Mon Jul 18, 2011 9:43 pm
I did cut the under grill part of the front clip but only for the solenoid box and freespool release lever.
If the solenoid box were remounted say in the engine bay and the gearbox rotated so the release lever pointed down, no cutting would have been needed.
I left the lever facing up so it would be easier to see and use.
That $400 chinese winch is still on there and still going strong... 8O No service or maintenance yet... :twisted:
I believe this is the other pic Santos meant to post.
Vehicle: 4wd
Post Posted: Mon Jul 18, 2011 11:17 pm
Has the standard bar been put ontop of the tube bar?
Do you think it would all still fit without the body lift?
Post Posted: Mon Jul 18, 2011 11:30 pm
It may possibly fit simbo, Mine is designed to fit with no bodylift for a larger Aldi 9500lbs. I have my ps box on the outside though for more winch room. Front clip is cut, but not the grill. Solinoid box will be inside the clip somewhere, and handle was modified to suit so it goes east west, instead of nrth south. (i was going to make one, then i accidently broke it anyway) :lol: Not for stock bar though. I will try and have a look later for you see if it fits.
Post Posted: Mon Jul 18, 2011 11:35 pm
Yes that was the pic, i'll go fix it soon. There is no real reason why awinch cant be mounted on its side (90 degrees, winch top facing front) or upside down is there?
-Santos
Post Posted: Mon Jul 18, 2011 11:38 pm
There must be a reason... How do the brakes work?
I've had the gearbox side apart and nothing much to it. Just a lock ring and a few gear sets.
Post Posted: Tue Jul 19, 2011 12:06 am
stockman wrote:
Has the standard bar been put ontop of the tube bar?Yes
Do you think it would all still fit without the body lift?Yes but you'd have to cut into the grille more.
It is possible but how would you mount it.. There would need to be some serious steelwork fitted.
Vehicle: 03 Jimny
Post Posted: Tue Jul 19, 2011 1:25 am
Just was looking at supershit new catologue and they have a 9500lb winch for $349
Post Posted: Tue Jul 19, 2011 11:03 am
cheaper than aldi! But if you want rope, tigerz is cost effective.
Converting cable to rope is dear.
Vehicle: 03 Jimny
Post Posted: Tue Jul 19, 2011 12:04 pm
I've got a tigerz11 winch I was just puting it out there
Post Posted: Tue Jul 19, 2011 12:11 pm
i just scored 45m of 10mm dynema for $202 :D
Users browsing this forum: Google [Bot] and 105 guests
