It is currently Mon Oct 19, 2026 2:57 pm
Post Posted: Sat Jul 05, 2008 4:52 pm
how you going fellas, went to put longer leafs in there rear yesterday and i notic this weird linkg think..
bein told its to stop axel tramp and springs from bending..
will it stop my car from flexing as much as it should...
also didnt get to put the longer leafs in... i forgot i had standard rear shackles :oops:
here is a pic of the arm
spoa, lux diffs, 2inch suspension, 2inch body, 1.6
Post Posted: Sat Jul 05, 2008 4:53 pm
that arm is the gay arm.... like i told u yesterday bro
Post Posted: Sat Jul 05, 2008 5:02 pm
yes its to stop axle warp/ tramp. shouldn't stop your car flexing if its made right. put up a pick of the other end where its mounted to the chassis
Post Posted: Sat Jul 05, 2008 6:16 pm
A- its not a gay arm......needed to stop axle wrap....pppfffft gay....some people....but the major prob i can see is someone has pointed the pinion to the t/case.....big no no....
Post Posted: Sat Jul 05, 2008 6:58 pm
Is this because of the UJ angles?
Post Posted: Sat Jul 05, 2008 7:18 pm
Yup, input and output should be at the same angle.
Post Posted: Sat Jul 05, 2008 8:57 pm
unless it has a CV at the Tcase end
Post Posted: Sat Jul 05, 2008 9:32 pm
What about using a double cardon joint? I suppose you would still have the same problem though.
Post Posted: Sat Jul 05, 2008 10:10 pm
Is it mounted to the chassis by what looks like a spring shackle?
Post Posted: Sat Jul 05, 2008 11:42 pm
its mounted to the chassis with a pivot style bearing hoop.. ill take another pic tomorrow
Post Posted: Sat Jul 05, 2008 11:50 pm
ok then... i see... your talking about the thingy mabobby again.....
i understand the idea of the bar to the diff but whats the go with the pinon to the tcase?
can someone please explain it in dumb arse language
Web wheeler extroadinaire
Post Posted: Sat Jul 05, 2008 11:54 pm
if you dont have the output of the Tcase joined to the pinion with a driveshaft you wont go anywhere when you put it in gear and let the clutch out, this can also affect your fuel economy
lots of 4wd's have the same in the front too
:cheers:
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 181 guests
