It is currently Sat Nov 07, 2026 3:04 am
Post Posted: Wed Aug 17, 2011 7:03 am
ok so i have new flairs for my pos. they are plastic wt flares but i have no idea how to attach them so they wont fall off..
they are genuine suzuki flares. i am just after ideas..
Phil
Post Posted: Wed Aug 17, 2011 7:17 am
Nut serts 8)
Vehicle: LJ20 LJ50
Image X 55
Camels have nice toes
Post Posted: Wed Aug 17, 2011 7:19 am
Rusho wrote:
Nut serts 8)
stainless nutserts tigged to the mounts??? (yes i am just coming up with excuses to use my new tig.
Post Posted: Wed Aug 17, 2011 7:20 am
TZAR wrote:
Image X 55
they would just tare off i recon.
Post Posted: Wed Aug 17, 2011 7:53 am
jonno_racing wrote:
Rusho wrote:
Nut serts 8)
That'll do :wink:
Post Posted: Wed Aug 17, 2011 8:53 am
m5 should do it.
Post Posted: Wed Aug 17, 2011 10:44 am
rivet
If in doubt power out!
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Wed Aug 17, 2011 12:08 pm
Are the the 88.5 wt Flares??
Dont they mount the same as tin Wt flares?
We are amphibious
Post Posted: Wed Aug 17, 2011 1:02 pm
jonno_racing wrote:
Rusho wrote:
Nut serts 8)
Is the mount made from stainless? If not, don't waste your time. Stainless threads bind and strip out far to easily. And welding them to mild steel is piontless. Just use zinc nutserts.
how are the metal ones connected? i wanna remove mine for paintjob but dunno how to get em off
Vehicle: 94 Sierra
Post Posted: Wed Aug 17, 2011 4:19 pm
Remove flare by unscrewing philip head bolts on inside of flare. May need to grind bolt heads of depending on rust. Buy one of these spot weld drills from Trade Tools or the like. Punch center of spot weld and slowly drill out first layer.
End Result.
Serious
Unbiased
Zook
Users
Know
It
Post Posted: Fri Aug 19, 2011 1:01 pm
are the screwed AND spot welded?
i dont understand fully. am i using a spot weld drill bit on the screw heads if there rusted too bad?
Vehicle: 94 Sierra
Post Posted: Fri Aug 19, 2011 1:22 pm
Grind the head of the Philip head bolts if they cannot be unscrewed. Use a cutoff wheel at right angles to the bolt being careful not to cut into the flare, or use a grinding wheel perpendicular to the bolt and stopping short of the flare. There maybe 6 and one nut at top center. Take the flare off and under the flare there is the flare holder that is spot welded to the guard. Its these spot welds that are drilled out.
Serious
Unbiased
Zook
Users
Know
It
Post Posted: Fri Aug 19, 2011 2:14 pm
ok now i get it. thanks heaps
Post Posted: Fri Aug 19, 2011 10:42 pm
Zuccinni, you are my new bestest friend!! I have never heard of the spot weld drill but faaaaark its looks a million times easiers and quicker AND neater then sitting there with a grinding wheel trying to take out the spot weld :D
Thanks heaps for giving me another toy to go out and buy!
Dave
Vehicle: 94 Sierra
Post Posted: Sat Aug 20, 2011 1:37 am
I can't take all the credit, another Suzuki enthusiast put me on to them. They work pretty good and the one bought has a doubled ended holesaw so I get two bites at the cherry.
Serious
Unbiased
Zook
Users
Know
It
Post Posted: Sat Aug 20, 2011 9:33 am
http://www.ebay.com.au/itm/120678177633 ... 1423.l2649
I found this bad boy, i really like the fact it has a shitload of extra cutter head things, the cheaper ones I looked at only had 1 or 2 extra heads. Just wondering wtf is the drill bit for? I get the crown cutter from your pic, do you use the cutter head as you have done then the drill be is to take the rest of the middle of the spot weld out?
Dave
Vehicle: 94 Sierra
Post Posted: Sat Aug 20, 2011 10:13 am
Yes, I reckon the drill is to take the rest of the spot weld off after you've cut it with the holesaw. If you noticed the drill point is fairly flat for that purpose. I only have the holesaw and arbour. The point on the arbour is to locate the tool in the punch indentation in the center of the spotweld. The point is spring loaded so when you push against it it slides into the body of the arbour. Take care because when the saw contacts the metal it might bite in and wander off. I just re-read your post and what saying is probably right.
Serious
Unbiased
Zook
Users
Know
It
Post Posted: Sat Aug 20, 2011 10:33 am
Okkies, when I sober up tomorrow I'll be spending some of my allowance money and buying it :D I know from expererience if I buy it tonight while pissed I might forget to pay it till I next log into eBay, could be a week or so :lol:
Dave
Users browsing this forum: No registered users and 352 guests
