It is currently Sat Nov 07, 2026 12:09 am
Vehicle: On the lookout
Post Posted: Wed Aug 17, 2011 9:52 pm
Help please anyone with a late model jimny, has to be at least 2005 plus facelift model, and preferably 2007 or newer with factory fit fog lights.
WHERE IS THE FRONT FOG LIGHT RELAY?
I can't find it, I can find the Fuse under the hood, but i can't findthe relay that's referred to in the wiring in the workshop manual. Any one know where it is?
Boring question I know, but if someone can help me I'll be able to write up a 'HOW TO' on how to wire up spotlights or add aftermarket fog lights through it. I've figured everything out except this relay. I have a few unidentified relays, but according to the workshop manual there should be a fuse box with a group of 3 relay slots, and only one out of the three used up by the fog light relay.
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Aug 17, 2011 10:51 pm
I found a plug connected to the headlight loom, down near the wires for the blinkers that could be it, and I also found what I presume it's the plug for the switch above the electric mirror adjuster, behind the black hole filler thingys... Hope this helps lol I can take pics when I get hom from work if you like?
Post Posted: Thu Aug 18, 2011 2:33 am
No need for pictures for those, I have them. Just not sure where this fog light relay is thanks for looking, confirms I'm looking in the right place.
Post Posted: Thu Aug 18, 2011 5:28 am
Why are you wiring up spotlights using the fog light circuit???
Just wire them up independently using the high beam as a trigger like other people do. There's the small complexity of negative switching but it's easy enough to solve.
2002 SWB GV
Lifted and Locked
Post Posted: Thu Aug 18, 2011 8:48 am
DONE!
And yes I did get a bit tangled up with the negative switching but its sorted now.
Post Posted: Thu Aug 18, 2011 9:00 pm
@squibby, even if you probably solved this already: you're looking for connector E132 (flat, 8 pins). The manual lists it as "Blower motor relay and front fog relay", so I think it's one common relay. Command from the dash switch comes to connector E132 on pins 6 and 7 to the relay, and you get a positive signal on pin 8. A green wire splits into two wires and goes to connectors E161 and E162 (2 pins, rounded) and then to the projectors.
Location of E132 and E161/E162:
@TheOtherLeft: if you want a separate switch (not related to high beam), this is the method :)
Suzuki JB43 2007
Post Posted: Thu Aug 18, 2011 10:27 pm
Thanks Vaxxi! I gave up though and just fed a new wire through the firewall. I did take my feed from under the dash (Red wire with silver spots) so I was able to rationalise the two wires down to only one with the help of the wiring diagrams!
Crispy old grand vitara
Users browsing this forum: Google [Bot] and 99 guests
