It is currently Sat Nov 07, 2026 3:04 am
Post Posted: Sat Aug 20, 2011 4:40 am
Hi All,
Instead of a half cut I manage to get a decent 97 2.0 4 cylinder swb and wanted to know if the front and rear bars as well as suspension are interchangeable?
Current car being 92 G16A swb with bull bars (front & rear), 2 inch body lift and 2 inch raised suspension.
Thanks in advance, did do a search but nothing definate.
Mic
Post Posted: Sat Aug 20, 2011 6:17 am
sv420 will have a different chassis so the bars wont fit without mods.
most of the suspension should be the same.
Post Posted: Sat Aug 20, 2011 1:36 pm
Suspension should be the same means what - same as the first statement - won't fit without mods - or same as the SE416, so it will fit without mods?
The chassis is wider and I'm pretty certain the suspension is different, wider cast control arms, as compared to pressed steel.
Post Posted: Sun Aug 21, 2011 2:49 am
well calmini kit fits both so i assume the suspention is the same.
i was told control arms are the same size, the extra width comes from the wider chassis.
Vehicle: 2001 XL7
Post Posted: Sun Aug 21, 2011 3:29 am
Your 2inch suspension lift in the front will become a 1 inch lift.
Post Posted: Sun Aug 21, 2011 3:46 am
they are exactly the same but different. :wink:
Post Posted: Sun Aug 21, 2011 6:56 am
yeh springs wont be the same bcause the 2L is heavier
Users browsing this forum: No registered users and 353 guests
