It is currently Sat Nov 07, 2026 3:03 am
Post Posted: Sat Aug 20, 2011 4:13 pm
i have been doing some reserch on ratios and gearing options for my jimny. i cant seem to find a deffinitive answer for one question. i have a 2002 manual jimny.
i want to know the correct ratio for the transfer case?
Jimny
I think that there are 1:1 (?) and 1.32:1 (?) transfer ratios. 4.3:1 (?) and 4.09:1 (?) Diff ratios and that the VVT manual gearbox is much lower in ratio as well.
SJ
ratios of 1.41:1 (1.3) and 1.58:1 (1.0)?
There seems to be alot of conflicting information on this out there.
I currantly run a set of 30", but willing to go to 33" to get some gearing options. just trying to gather as much info as i can so i can do some calculation and figure out which way to go. i am even considering going for an sj transfer or even vvt diffs the other option is to go for a vvt gearbox. will see what i come up with. will keep you all posted as to what i figure is the best way for me to go. i may just have to pull it out and have a look.
Post Posted: Sat Aug 20, 2011 7:04 pm
http://www.auszookers.com/index.php?nam ... ic&t=22383
:wink:
Post Posted: Sat Aug 20, 2011 8:25 pm
"well first I would figure out exactly if you want to go larger tyres or not ...
Definately a swap to a sj transfer ... Then throw some gears in it..
4.16 if your keeping the 30s
4.9 or 5.16 if your going to run 31s/32s
6.5 if your going 33s
Post Posted: Sun Aug 21, 2011 1:22 am
Yeah, the only worry I have is that if I have a 1:1 transfer and I install 4.9:1 reduction gears (16%) which are intended for a transfer with 1.41:1 would that not be a much larger reduction? Like say I use 4.9's (1.63:1) that would be a 63% reduction, and that would suck.
Post Posted: Sun Aug 21, 2011 2:44 am
What year model do you have?
Post Posted: Sun Aug 21, 2011 2:49 am
Just read you have a 02.. Pretty sure you wont have a 1:1 ..
Post Posted: Sun Aug 21, 2011 4:12 am
Well I hope so :)
Post Posted: Sun Aug 21, 2011 9:21 am
pretty sure they were a vvt only thing..
Post Posted: Sun Aug 21, 2011 12:12 pm
that would bring your car back to factory on HI, but wht about LOW, it would be still the same as factory or ull have more reduction??
to be honest I would loooove bit more reduction, factory one works well but on big downhills it goes too fast for my taste...
Users browsing this forum: No registered users and 379 guests
