It is currently Sat Nov 07, 2026 1:43 am
Post Posted: Tue Aug 23, 2011 1:57 am
just a quick question about my snorkel
this snorkel on a different car now but set up the exact same.
its been raining for days here and i was wondering would water get in the snorkel and what do people do to stop it going to air box?
93 sierra 2"spring2"body 31,s & 4.9s
Post Posted: Tue Aug 23, 2011 2:04 am
The airbox usually has a drain hole in the bottom for water to get out. I doubt you'd get much if any in there anyway
Post Posted: Tue Aug 23, 2011 2:09 am
yeah im not to worried was just talking to bogga and then thought id see what other people did
Vehicle: On the lookout
Post Posted: Tue Aug 23, 2011 2:18 am
I can't see any problem if a little moisture got past the air filter anyway.
Crispy old grand vitara
Post Posted: Tue Aug 23, 2011 2:42 am
most of the snorkel heads are designed with rain channels, the minimal amount that gets past there would dissipate inside the snorkel while travelling to the airbox, from there it's most likely just moisture in the air.
Post Posted: Tue Aug 23, 2011 2:51 am
learning things every day. thanks guys.
Post Posted: Tue Aug 23, 2011 6:38 am
turn the snorkel head backwards :wink:
Member of C.O.R 4x4
Post Posted: Tue Aug 23, 2011 8:02 am
a drain hole in the bottom of the air box can not only let water out, but it can let water in. i have filled mine on my cruiser and sealed my airbox and snorkel with goo.
Post Posted: Tue Aug 23, 2011 8:11 am
landcruser snorkels are not meant to keep water out, like most stuff on landcrusers
they are just bling so city people can pretend that they are bushies. :wink:
Post Posted: Tue Aug 23, 2011 8:44 am
you'd have to be under water for an immensely long time for water to fill the airbox through the 1mm drain hole... by that stage you'd have turned off the motor and been towed out anyway =)
Post Posted: Tue Aug 23, 2011 9:34 am
hence why i had to goop mine up. i had water over the bonnet last wet season trying to drop the missus to work!!
Users browsing this forum: No registered users and 113 guests
