It is currently Sat Nov 07, 2026 10:02 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2  Next
Post Posted: Sat Sep 03, 2011 10:50 pm
hey guys i want to get a ruf done on my car but i dont think i would be able to do it myself so im just wondering how much one of you fabricating gods would charge to ruf my car, its a 1988 wt sierra
Post Posted: Sat Sep 03, 2011 11:15 pm
It would depend on who does it I think mate. Different people would do it different ways. Fatzook would be a likely candidate 8)
Post Posted: Sun Sep 04, 2011 12:52 am
Semi RUF or full RUF... $200 for semi and $400 for full. Day turn around, drive in drive out with you providing the rear springs. I know your on the goldcoast but I thought I would give people closer to me an idea....
Vehicle: Work van
Post Posted: Sun Sep 04, 2011 12:58 am
Is that mates rates?? :lol:
Swb softie spoa cromo front -50 beadlocks 6.5s :D
Post Posted: Sun Sep 04, 2011 1:02 am
If I've done my 50+hrs for the week that pretty good to go fabbing on a Saturday, and there is allot of work with a full ruf, WT especially....
Vehicle: Work van
Post Posted: Sun Sep 04, 2011 1:10 am
It sounds like a good price especially for weekend work :D
I'll pm you about it and that other stuff aswell
Vehicle: LJ20 LJ50
Post Posted: Sun Sep 04, 2011 1:13 am
how much would one of you charge to ruf my car
Just get Shep to work on your car and I guarantee it will be "ruf" :thefinger:
Camels have nice toes
Post Posted: Sun Sep 04, 2011 1:14 am
No worries joshy, look forward to hearing from you :D
Post Posted: Sun Sep 04, 2011 1:18 am
*ahem* :helloo:
Post Posted: Sun Sep 04, 2011 1:42 am
Lol dan, you can pm me also if you like.... I need to put an add up in the directory..... Need to think of a good name....
Post Posted: Sun Sep 04, 2011 1:43 am
RUFF JOSH's Spring Fab
Post Posted: Sun Sep 04, 2011 1:59 am
:lol:
DUB-ENG ? my ol man called me dubbo since I can remember, and the other word is engineering shortened.... Or DUB-FAB....?
Vehicle: Work van
Post Posted: Sun Sep 04, 2011 2:17 am
I get it now :crazy: I thought you were getting new numberplates :lol:
Post Posted: Sun Sep 04, 2011 2:27 am
you wrote what i was thinking. :lol:
Post Posted: Sun Sep 04, 2011 4:42 am
I am sure what 31zook means is the price will vary depending on how the rear springs are fitted to the front of the vehicle. Because as has been discussed so many times before there is no such thing as a semi RUF, half RUF or full RUF, you either have rear springs in the front or you do not.
Post Posted: Sun Sep 04, 2011 6:07 am
All I mean Is if you want your front hangers cut off and moved so you can run standard shackles or you want to just run 50mm longer shackles and move the rear holes back... Does that clear it up a bit?
Post Posted: Sun Sep 04, 2011 6:27 am
$200 for lazy half finished and $400 for proper effort filled ruf. Day turn around, drive in drive out with you providing the rear springs.
Like that?
Post Posted: Sun Sep 04, 2011 8:07 am
about 3-4 grand :wink:
Post Posted: Sun Sep 04, 2011 8:43 am
Like that?
Ahh, no, both are drivable one is better quality then the other, but both will perform the pretty similar...
Post Posted: Sun Sep 04, 2011 9:05 am
Like that?
I'm trying to go to both extremes to keep the "no such thing as a half ruf" people happy :lol:
Post Posted: Sun Sep 04, 2011 9:11 am
Like that?
you mean one is worth doing but both use rear springs :wink:
Post Posted: Sun Sep 04, 2011 9:12 am
ajsr wrote:
Like that?
Thats what I mean..
Post Posted: Sun Sep 04, 2011 9:44 am
One is also bolt on reversible. Some (steve) think that everyone is doing this mod dodgy, yes but my work isn't. My new lwb build will be engineered, using most of my original bits....
Post Posted: Fri Dec 09, 2011 12:20 pm
I will stick to my guns on this, describing it as full or half does not make any sence in relation to the actual modifiation. It is simply a rear up front and this is best descibed as RUF with mounts moved or without mounts moved. Either way it is still rear springs in the front of the vehicle, how it is done is up to the individual and that decisionwill be based on his understanding of a number of factors if you have not given consideration to things like steering arm bind, shock compression angle, caster and bump stop position then you have not fully looked into all the implications of the modification.
Vehicle: 93 Sierra
Post Posted: Fri Dec 09, 2011 1:42 pm
2stroker wrote:
... if you have not given consideration to things like steering arm bind, shock compression angle, caster and bump stop position then you have not fully looked into all the implications of the modification.
I did my thinking with a grinder :)
Post Posted: Fri Dec 09, 2011 1:50 pm
price is not a factor in this, its quality of work. there is only one way to do this, and thats paying a good fabricator to do it. if you dont do it properlly you could screw your chassis, get pulled up by transport, or it could look like shit. you want your car to look normal when someone gets under to look at it. thats my opinion on RUF's.
Post Posted: Fri Dec 09, 2011 8:29 pm
u know that you can just use the rear springs with some 2' boomerang style shackles, tailshaft spacr and extended brake lines, with no cutting welding or drilling.
I ran mine like this for about 2yrs with heaps of flex and smoother ride :helloo:
Post Posted: Fri Dec 09, 2011 8:35 pm
I'm sick of hearing about your boomerang shackles. It doesn't matter what shape the shackles are, the fact is if you draw a straight line from one end to the other the angle doesn't change, it still sucks :roll:
Post Posted: Fri Dec 09, 2011 8:37 pm
and what exactly is the problem with it ?
Post Posted: Fri Dec 09, 2011 8:53 pm
Search is your friend :roll:
shackle angle discussion
Users browsing this forum: Google [Bot] and 90 guests
