It is currently Sat Nov 07, 2026 12:51 pm
Vehicle: Suzuki LJ50 & LJ81
Post Posted: Wed Sep 14, 2011 9:07 am
Has anyone used compressed air to pop out the dints in a fuel tank? What sort of pressure would it need? Any thoughts before I take it down the servo and hook it up? (I don't want to blow it up at home :wink: )
Post Posted: Wed Sep 14, 2011 9:29 am
I just do it at home. Then I build a bash guard....
Post Posted: Wed Sep 14, 2011 9:31 am
Yes,be very very careful of the fumes. The compressed air when it blows through produces fumes (not a mist which is not as bad) you can see the "mirage" of the vapors flowing out any where air may leak.
Even a tiny spark would mean a very big boom.
How much pressure do they need? Just start with a little and keep going? What is a good way to seal up the filler neck?
Vehicle: Daisy
Post Posted: Wed Sep 14, 2011 9:33 am
Some here have used a rag so it's kind of it's own over pressure relief, you don't want too much and blow the seams.
Post Posted: Wed Sep 14, 2011 9:34 am
Didn't think of that....turning into a molotov cocktail. 8O
Post Posted: Wed Sep 14, 2011 9:35 am
I think I may need to set up the video camera....for Youtube.
Post Posted: Wed Sep 14, 2011 9:43 am
I cracked my tank by using little mounts of air so be careful with the trigger :D
Post Posted: Wed Sep 14, 2011 9:57 am
Yep the rag for a pressure relief =good idea.
we did a tail pipe once, and we used a potato to seal on end, and on the other we also plugged with a potato, but shoved the air thingo through the potato on one side for a good seal.. Popped the dints right out.
Then we shot the one plug potato out like the pipe was a cannon armsup
Users browsing this forum: Google [Bot] and 76 guests
